20 Most Recent
Samsung SGH-T499 Questions & Answers
How to set music as message tone on samsung sgh-t499
there's an app called RingoLite or just Ringo, and it lets you assign ringtones to your contacts. My bf used it on his samsung phone and he said it works. If all else fails, you gotta do it the old fashioned way and record the song you want as a voice memo lol I believe samsung lets you assign your own recordings as ringtones.
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Sght599 backup pin
Press volume up, menu and power buttons. When Samsung logo appears let power button go till a dumping of menu appears. Now scroll with volume down key and select wipe data to factory reset your phone. Note, you will loose your personal contacts, photos, and any file on phone but problem solved.
Forgot pattern screen lock
play with power button and volume up button simultaneously
hard reset option will pop up
but it'll erase all your personal data
Firmware download
ik heb een probleem met samsung gt-e1080i
mijn phone passwoord ben ik vergeten
Unlock code
Free unlock code is not possible for this models.So,better You can get paid unlock code for your Samsung SGH-T499 mobile from
Unlock-Zone.com here you need to specify your country,Network name to which it is locked.IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.
Unlock code
Free Unlock code is not possible to get for this SAMSUNG SGH T499.You need to pay to get unlock code.Visit the site
Simpleunlocking.com get unlock code and unlock it easily.
