20 Most Recent Hozelock 2490 Auto Reel 20m Hose 12.5mm Questions & Answers
6answers
How can
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
9/7/2021 7:14:23 PM • Hozelock 2490... • Answered on Sep 07, 2021
Lost return tension when replacing hose
Where can I get a replacement tension spring for my auto reel hoselock 2490 ? I have tried everywhere but without success. Any help is much appreciated
4/20/2019 2:16:51 PM • Hozelock 2490... • Answered on Apr 20, 2019
How can I fix a hozelock hose reel that has been pulled out too much and jammed?
you have to take the cover off and redo the hose you can re reel back in
7/20/2014 10:45:14 AM • Hozelock 2490... • Answered on Jul 20, 2014
I have a hozelock heavy duty pressure washer model 7902 0000 and am looking for a replacement lance or gun. Hozelock has discontinued this range.
notify hozelock for replacement even if discontinued usually have parts available for replacement or if out of stock an aftermarket part plus most guns are a threaded to accept a hose
8/27/2021 12:08:48 PM • Hozelock Garden • Answered on Aug 27, 2021
2answers
My hozelock spray gun leaks heavily from under the
please i m in problem ?
6/16/2021 3:45:28 AM • Hozelock Garden • Answered on Jun 16, 2021
My auto hozelock started clanking when I wound it back and now it will not lock into position when I pull it.
The gear has broken! Take apart and replace!
5/24/2020 7:26:55 PM • Hozelock Garden • Answered on May 24, 2020
Do I need a special screwdriver to open the casing of the Hozelock wall mounted autoreel garden hose?
Get a small penlight and peek at the head of whatever seems to holding it. If it isn't normal slotted or "X" phillips it might just be Torx. Torx screws have a star shaped head and only Torx drives will fit. Either get small set from HD or maybe buy just a couple from open stock. They come in "10" sized, ie; 10, 20, 30 etc. If Harbor Freight has them, they are ok for just a few uses and you won't be out much if you get the whole set.
9/28/2019 8:48:42 PM • Hozelock Garden • Answered on Sep 28, 2019
My hozelock 2490 no longer winds the hose back into the body - how can I get it working again ?
have the spring replaced or readjusted
7/29/2019 10:32:59 AM • Hozelock Garden • Answered on Jul 29, 2019
Why has one of my Hozelock drippers stopped working? All the rest are working.
It is possibly clogged. Try opening it with a paper clip or very small wire.
7/11/2019 9:29:17 PM • Hozelock Garden • Answered on Jul 11, 2019
How do i remove an older hozelock assembly from the wall
How ever it is attached to wall ......screws,bolts undo them
11/7/2018 6:31:10 PM • Hozelock Garden • Answered on Nov 07, 2018
How do I set automatic timer on AC1 Hozelock watering system?
incorrect operation. 1. Remove screws and back cover. 2. Insert two 1.5V 'C' Alkaline batteries. (Check + and - are correct.). IMPORTANT: Rechargeable batteries must not be used. 3. Replace batteries each season. (max 12 months use) MAINTAINING THE WATERPROOF SEAL 1. Ensure that rubber seal is positioned correctly. 2. Replace back cover and screw down tightly. 3. Repeat each time back cover is removed. HOW TO PROGRAMME THE TIMER There are two watering operations - Automatic and Manual. AUTOMATIC OPERATION Automatic ON 1. Turn dial clockwise to AUTO START at actual desired start time (e.g. To start watering each day at 15H00 you must set your AC1 when the actual time of day is 15H00). The timer has now memorised the auto start time until it is reset and will operate every day at this time. Use of manual ON or OFF does not cancel memory. 2. Turn dial anti-clockwise to: a) Chosen duration for once-a-day operation, or b) Chosen programme for all other watering frequencies (see table). The timer will now automatically run the selected program repeatedly until a new option is selected. GB 2 Automatic OFF Turn dial to Manual ON or OFF. If you wish to return to Automatic watering re-select the desired watering programme. NOTE your auto start time remains memorised until a new one is selected. Changing start time Turn dial clockwise to AUTO START at new chosen start time. Changing watering programme Turn dial to new programme. Do not turn dial to AUTO START unless a new start time is desired. MANUAL OPERATION Manual ON Turn dial anti-clockwise to ON. Water will flow for 60 minutes maximum or until turned to OFF setting. Note: After 60 minutes water shuts off. Knob will still point to ON and needs to be manually set to OFF or to desired number of automatic watering minutes. Manual OFF Turn dial clockwise to OFF. Note: Operation is only audible when valve opens and closes. To check that timer is working, switch to manual ON or OFF to hear valve operate. CONNECTING THE TIMER TO THE TAP Use supplied adapters if required. Tighten to ensure no leaks
6/25/2018 1:04:42 PM • Hozelock Garden • Answered on Jun 25, 2018
Hozelock 2490 Auto Reel 20m Hose 12.5mm Logo
34 questions posted
Top Hozelock Garden Experts
Jay Finke
Jay Finke
john h
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
View Most Popular
Hozelock Garden
  • Hozelock Garden
Most Popular Question
how can
  • Garden
