20 Most Recent Hotpoint WML520 Washing Machine Questions & Answers
WML520 Not draining water
Timer may be shot.
10/28/2017 3:01:53 PM • Hotpoint WML520... • Answered on Oct 28, 2017
Comfort fluid does not go to drum
Clean the soap dispencer
2/16/2016 11:54:01 PM • Hotpoint WML520... • Answered on Feb 16, 2016
During a cycle machines makes rattling-clicking sound and does not spin. Machine is able to spin and drain without clothes inside.
No wash agitation or spin? try these: WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open. Another test u can make with a multi meter is by testing the prongs individually. # 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch. (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open. . Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly. Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it. Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Transmission or clutch assembly not engaging due to going out or slipping. Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly. CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub) Remember to check the agitator spline as well for worn broken teeth. By the way my advice is free cuz God is good! 26069595-hdpcwx0uwo4iizhnlkec22xy-5-0.jpg 26069595-hdpcwx0uwo4iizhnlkec22xy-5-2.jpg 26069595-hdpcwx0uwo4iizhnlkec22xy-5-5.jpg 26069595-hdpcwx0uwo4iizhnlkec22xy-5-9.jpg 26069595-hdpcwx0uwo4iizhnlkec22xy-5-14.jpg 26069595-hdpcwx0uwo4iizhnlkec22xy-5-20.jpg 26069595-hdpcwx0uwo4iizhnlkec22xy-5-27.jpg
1/29/2016 3:22:19 AM • Hotpoint WML520... • Answered on Jan 29, 2016
It doesnt complete some cycles and all the lights start flashing
I recommend you review your Owner's manual trouble shooting section. No manual? Try manualslib.com
5/4/2015 2:48:08 PM • Hotpoint WML520... • Answered on May 04, 2015
Machine doesnt complete some of its programs and all the lights start flashing
check pump for blockage
4/27/2015 9:01:43 AM • Hotpoint WML520... • Answered on Apr 27, 2015
Hotpoint wml520 flashing lights
you have a problem with the board
1/17/2015 1:25:22 PM • Hotpoint WML520... • Answered on Jan 17, 2015
NOT Filling with Water
The filter at the back of the inlet valve may need cleaning. The inlet valve may no longer work.
11/8/2014 6:15:30 PM • Hotpoint WML520... • Answered on Nov 08, 2014
How do you get at the filter?
It should be at the front of the machine down the bottom or underneath th machine.
4/8/2013 5:46:14 PM • Hotpoint WML520... • Answered on Apr 08, 2013
How do you take the cap off to check the filter is'nt blocked
Wheres drain plug usually at bottom front face filter often behind drain plug
3/23/2013 7:03:24 PM • Hotpoint WML520... • Answered on Mar 23, 2013
Draining prolem
Have you checked the pump filter for blockages? I had the very same problem and this was the cause.
1/23/2013 8:47:25 AM • Hotpoint WML520... • Answered on Jan 23, 2013
Hotpoint WML520 Washing Machine Logo
54 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint wml520 flashing lights
  • Washing Machines
