20 Most Recent
Acer Aspire 5742G Questions & Answers
No booting broblem
I guess the CPU isnt completely ruled out. It might have a bad pin, or your mobo might have a bad socket that got fixed when you jiggled it..but that would be a big problem, and you'll have to take your cpu and look closely at it and the mobo to look for defects. If its overheating it wouldnt do it immediately. It would get past POST and problem overheat at "starting windows". and if it did that most mobo's will display an error message before POSTing that says it had to shut down your system to prevent overheating.Plus you also have a decent cpu cooler, so even if you did a terrible job putting on the thermal paste it shouldnt cause your cpu to overheat, unless you have doing a huge overclock, then it might happen.Are you overclocked right now? have you tried setting everything back to stock speeds and booting like that?I can help you via for fixing computer problem on internet via teamviewer in 1 hour Email
[email protected] or call me 9004108811or refer below site 2 get solution
Source(s):
http://goo.gl/m35bL
Acer 5742g Beep at boot up
I have a problem that looks like this one.At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.If I press the power button, it stops beeping. When I release it, it starts beeping again.If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.Any clue?
I/O device error
Two of the most common causes of I/O (Input / Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motor like force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else. Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; Otherwise, Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. b>
Acer won't restore
It sounds like you have a HDD fault, Your hard drive has become faulty or damaged. Has your Acer been dropped or banged? The lid slammed shut?If you have tried to reinstall your OS and failed, its definately a HDD fault.
