20 Most Recent
Bobcat 773 Questions & Answers
We have a bobcat 763
so the pump is weak, due to it is, or regulator or filters clogged
what you have there on the supply side, who knows that?
my guess is , not reading the kabuto engine spec on fuel pressure
and is wrong.. lift pumps too.
10/24/2022 6:18:16 PM •
Bobcat 773
Answered
on Oct 24, 2022
How do I change the alternator on a Bobcat 773 skidsteer loader
Why do you suspect the alternator? Have you checked the output? Put a meter across the battery terminals when running at fast idle and it should be 14.5volts and no less than 13. Poor cold start is usually the heater plugs/ failed heater plug timer or poor battery strength. Start at the beginning and see if the alternator is working OK, then work through the rest. Test the heater plug supply by putting the meter from the plug supply cable to ground when the switch is in cold start position. Should have 12v at least. Make sure both battery cables have good clean connections at both ends to chassis or starter. Most cold start problems can be fixed by careful maintenance and basic systems checks.
3/4/2020 11:47:28 AM •
Bobcat 773
Answered
on Mar 04, 2020
