20 Most Recent Samsung Galaxy Gio s5660 Questions & Answers
8answers
Recover deleted contacts from phone memory for samsung galaxy
If you lost Samsung data like contacts, photos, messages, videos or other files, you can try Samsung Data Recovery. It can easily recover deleted/lost Photos, Messages, Contacts, Call Logs, WhatsApp, Musics, Videos etc. from All Samsung Devices. It is also capable of previewing data on Samsung freely and selectively before the recovery. Here are some related articles: Galaxy S6 Data Recovery - Recover Photos, Contacts, Messages from Galaxy S6/S6 Edge How to Restore Deleted Pictures, Videos, Files on Samsung Tablets How to Recover Deleted Photos from Samsung Galaxy S3 How to Recover Data from Samsung Galaxy Note 4/5 The Best Way to Perform Samsung Galaxy S3 Contact Recovery recover-deleted-contacts-from-phone-pncr5ctcj1j4uduw0oqfngti-2-0.jpg recover-deleted-contacts-from-phone-pncr5ctcj1j4uduw0oqfngti-2-2.jpg
3/12/2021 2:52:59 AM • Samsung Galaxy... • Answered on Mar 12, 2021
My phone is Samsung Galaxy Mini 2 or S5660D and
The charge connection is loose. If it is a Micro USB connector, check inside the jack with a strong light and see if the tiny contact board is bent downward. If it is, then it must be carefully bent up a bit. Use a wooden toothpick and insert the point below the contact board to push it up. Then try using a new Micro USB cable and charger.
5/18/2019 1:35:47 AM • Samsung Galaxy... • Answered on May 18, 2019
2answers
Free unlock codes for samsung galaxy Gio
Free codes does not work some times..So better you will get the code from http://www.mobileunlocksolutions.com/ .It helps to unlock your samsung mobile easily.
12/28/2018 1:25:29 AM • Samsung Galaxy... • Answered on Dec 28, 2018
When I try to get google play, it says "this browser is no longer supported, please use the google play store app to access google play. But when I click the link it says "Missing ID. No ID passed wit
Firstly try updating your device, Google Play will likely update with it. navigate: Settings > About > Software Updates and it will check for any updates available for your device (This is based on a newer version of android so it may be slightly different). If this does not work try navigating to Google Play through your browser. Try this link: Google Play. If your device is hooked up to your Google account you can also install apps through your computer. When there search for "Google Play" in the search box and download it that way. I hope this helps, Aaron
7/7/2018 7:06:46 AM • Samsung Galaxy... • Answered on Jul 07, 2018
Unlocking touch screen or reset my samsung galaxy
Other solution is to reset (factory reset) your phone. But all your saved files from device will be deleted. If you're decided to take the loss kindly state your samsung model/series.
2/5/2018 1:30:03 AM • Samsung Galaxy... • Answered on Feb 05, 2018
I am getting a ER05 Msg on my Samsug S5 in Europe. The phone was uncloced to be used in europe. Everything works fine (I think) but Im getting this message
Most likely you have WiFi calling enabled, and the local provider SIM doesn't support it. Turn off WiFi calling, and you should stop getting the ER05 message: 1. While you are in Settings, swipe to Network Connections. 2. Hit More networks. 3. Slide the Wi-Fi Calling Switch to OFF mode.
8/4/2015 1:17:44 PM • Samsung Galaxy... • Answered on Aug 04, 2015
Camera hanging problem
back up your phone & do hard reset by recovery options,data will be lost
12/22/2014 9:59:43 AM • Samsung Galaxy... • Answered on Dec 22, 2014
Touch screen
change touchpad
12/22/2014 6:09:11 AM • Samsung Galaxy... • Answered on Dec 22, 2014
Where do I find call barring settings on my Samsung galaxy gio s5660 please help?
in System Settings -> under Network
10/14/2014 4:42:49 AM • Samsung Galaxy... • Answered on Oct 14, 2014
My galaxy gio fell now not working
http://www.samsung.com/ca/support/usefulsoftware/KIES/ ( make sure your battery is fully charged ) (1)Do a system Backup with Kies (2) Go to settings privacy (3) select the checkbox backup my data & automatic restore (4) Factory data reset BUT leave format sd card unchecked (5) Reset Phone (6) Erase everything (8) wait for it to restore back to factory settings on your phone (10) if that didn't work let me know ( GOOD LUCK )
9/30/2014 12:44:32 AM • Samsung Galaxy... • Answered on Sep 30, 2014
How to reboot or unlock a samsung Gio s5660
Press Power Key and Volume Down Key at same time..after some time a menu will be appear then select wipe cache and wipe data.. and reboot ur mobile
7/23/2014 10:35:09 AM • Samsung Galaxy... • Answered on Jul 23, 2014
No sync with gmail contacts
Solution One : Use this app(Its is the Link) to make your problem OK ! Solution Two : Its a server problem! If the app works out Please do like my page Techno Trust @ fb.com/technotrust Contacts Sync Fix Android Apps on Google Play
4/18/2014 2:25:14 PM • Samsung Galaxy... • Answered on Apr 18, 2014
2answers
I need free unlock codes for samsung gio,imei 357823040340782.please e mail [email protected]. or give codes here thanks
Hi free unlock code are un trustable many times .I recommend you to visit Onlinegsmunlock.com to unlock your Samsung Gio mobile from network lock .Here they ask you the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
2/8/2014 5:25:17 PM • Samsung Galaxy... • Answered on Feb 08, 2014
Deleting multiples sms messages on a samsung galaxy gio
use option delete then delete all messages
12/21/2013 4:56:03 PM • Samsung Galaxy... • Answered on Dec 21, 2013
Message memory full
I will first take a back up of your Galaxi in the computer and reinstal the oerative system tha cleans every thing. And you telefon will be as new. I use to do with my computer, the iphone of my son and it works all ways. check the handbook of your mobile how to make a system restore first and if it does not help try reinstaling the operative system ( as second option ) that i guess is windows in your Galaxi you find out of it in the handbook or try youtube.god luck!
11/13/2013 4:57:25 AM • Samsung Galaxy... • Answered on Nov 13, 2013
Pattern unlock
unlock
10/25/2013 1:24:49 PM • Samsung Galaxy... • Answered on Oct 25, 2013
Samsung Galaxy Gio s5660 Logo
155 questions posted
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
when try get google play says browser
  • Cell Phones
