20 Most Recent
Samsung GT S3850 Corby II Questions & Answers
My deleted file is in the sd card.. can the phone
Usually the SD card is a secondary storage device ... and separate from the (internal) phone memory. To determine / test this, see if your phone still have (some) information when you remove the SD card from the phone... e.g. your telephone contact list, etc.Yes, you can try to recover the "deleted" file on the SD card using a PC / laptop ... using a data recovery utility/tool (on your PC) to scan the storage space or "undelete" that deleted file.. If your phone can be attached to a PC (e.g. via USB), and if your PC recognizes the "storage" disk on your phone as an "external" disk, you may also be able to use a data recovery utility to scan the storage space or "undelete" that deleted file.
Reset password
Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. You shouldn't need internet connectivity to unlock the phone. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the device is using or the original password used.
In some cases, if the device can receive a call, you can access the menu during the call and disable the screen lock.
If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion
If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/
BUT... A recovered account or changed password won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost.
An article on this topic: http://einartysen.se/unlock-android-phone-after-too-many-pattern-attempts/
How to recover samsung s3850?
download Samsung Kies from samsung.com, then pdate your firmwire using it with your CORBY 2 in download/flashing mode.to view download/flashing mode, search in youtube/google.
Unlocking code of dragon hunter
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How to block my stolen phone?
If your
mobile phone is lost or stolen you can inform your cell phone provider with your IMEI number. Your cell phone provider can then put the serial number on a shared database. This list stops this particular phone from registering on any network and will be useless for anyone even if the mobile phone's
SIM card is changed. If your cell phone is GPS enabled then it is possible to track, but you need to contact your cell phone service provider. Otherwise I suggest you contact your cell phone provider ASAP. To lock/block your cell phone from further use, please click on this link :-
http://www.fixya.com/support/r5057854-lost_or_stolen_cell_phone
