The power supply section of the tv may be faulty. Open your gadget and check if there are no popped up capacitors. When a capacitor at the power supply section is afftected by a surge, normally it pops up and resultantly affects the switching of the tv ....so check its voltage rating and capacitance and replace with the same value taking note of the polarity of the capacitor
You must first run LAN line from the TV to your router.Make sure the clock is set on the TVHit viera cast on your remote and you will be connected to the apps that are supplied to panasonic.If you haven't already set up your internet. you need to do so through the user menu. Auto set up works best for novice users.
This happened to me yesterday. My daughter put a penny and a dime in the SD slot and none of the buttons or volume were working on my TV.Only the power button would work.
I fixed it by simply removing the penny and dime out of the SD slot and then i held the power button for 10 seconds. After I unplugged the TV from its power source for 5 minutes and then plug it back in. When I turned the TV back on everything was back to normal.
For a second I thought I was going to have to buy a new TV, lol. Hope this helps. If it doesn't work the first time then try it a second time.
By the way I have a Panasonic PT-52LCX66 LCD Projection TV..
Hello
There are two types of guarante that a company offers to a customer. You must read the warrany conditions very well before buying any product. Some of them will give replacement waranty to their product. Some of them will offer only warannty. For the first, if the set shows any problem during its warranty period, the company will replace it with a new one without any question. For the second, they give only wararnty to you. Not a replacement waranty. They have only to do is to repair the faulty set and get it back to you. That is all. Sometimes, there may be delay in getting the spare parts. Sometimes it may tak months. There is no predicted time for that. On some occations, they will ask you the cost of component, as thay claim that the failure occured by your use. If so, that amoun vertually contain their service charge too. I thinks that you got me.
So when you go to buy an other product, buy ony the product that the company assures replacement warranty for a period of 6 months or so. If you have bought the set without replacement warranty now, you will have to suffer. OK.
Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
JustAnswerhttps://www.justanswer.com > Electronics Question
Jan 5, 2018 - The F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Reddit · r/VHS2 comments · 2 years ago
The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
