20 Most Recent
Canon iR2018N Questions & Answers
Canon iR2018N showing system error E007
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
pic of fixing film
How do i fix error e261 on canon ir2018
I suspect the fans in the unit are not clear or open. One for the optics an fuser. Make sure all connectors are tight. If cleaning does not work a new power supply board may be needed an controller.
How can i reset my canon printer error code 007
Error code is regarding fixing unite.
1 check Teflon sleeve in fixing , if found damaged than replace,
2 check lower pressure roller and end rubber gear if found damage replace it
3 now start copier press buttons in following sequence
Addi. function *
than 28
again *
than on panel its display " COPIER"
touch it, than again touch on "FUNCTION"
Than Touch on "ERR"
than Touch "OK"
than switch off machine and again start.
machine will ready
My iR2018N canon xerox machine problem is display
If you have already tried a new toner cartridge, try another one. Ensure you are using an approved toner cartridge for your model machine. Your toner supplier should have all the required information to provide you with the correct toner. If multiple toners have been attempted and it still fails to properly acknowledge them, call for service.
11/29/2013 11:37:35 PM •
Canon iR2018N
Answered
on Nov 29, 2013
E197
ir2018nerrcode001or808
