20 Most Recent
Daenyx DN-26D 26-in. LCD HDTV/DVD Combo Questions & Answers
What is tv code for daenyx
You will need to provide the make and model of the remote control device that you are using to control the Daenyx DN-26D.
Unlocking code for daenyx dn-26d
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "
How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
What s the code with universal remote urc-386
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
DVD stuck in
About the only way I would tackle this is to take apart the unit and free it.
Daenyx TV DVD Player Error
You either have a dirty optical pickup or a bad one in the unit--it reads the disc.They do make a cleaning disc but that is only 50-50 chance(sometimes a disc gets put in with some kind of residue on it)If bad the built in player will cost more to fix/replace than a cheap external unit connected to rear inputs in place of it--this is the real issue with combo units--usually cheaply made etc.
