20 Most Recent
Hotpoint Aquarius WT540 Front Questions & Answers
All lights flashing
just fixed 1 of these this morning.....was the main board at rear of machine in bottom corner.........
cheers
3/10/2015 7:43:30 PM •
Hotpoint...
Answered
on Mar 10, 2015
My washing machine is not working
Sounds like a communication error.
remove lid and unplug top consol panel for 5 mins ,make sure connections on bottom pcb are tight ,if that dont work replace your PCB
3/9/2015 12:35:20 PM •
Hotpoint...
Answered
on Mar 09, 2015
Drum will not turn
Again need more info like model # of dyer or at least brand name and type
2/7/2013 10:38:20 AM •
Hotpoint...
Answered
on Feb 07, 2013
Lights are flashing on my unit and cycle will not
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
9/24/2011 4:09:43 PM •
Hotpoint...
Answered
on Sep 24, 2011
All lights flashing will not start
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
John C
9/19/2011 12:03:03 PM •
Hotpoint...
Answered
on Sep 19, 2011
