20 Most Recent Epson PhotoPC L410 Digital Camera Questions & Answers
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
4/5/2008 1:31:55 PM • Epson PhotoPC... • Answered on Apr 05, 2008
Nothing appears on the LCD screen.
You can try a new battery for it or reseat the flash card if that doesnt work still try another flash card.
4/4/2008 5:53:48 PM • Epson PhotoPC... • Answered on Apr 04, 2008
Is the camera’s internal memory available when a memory card is installed?
The camera’s internal memory is not used to store pictures when a memory card is installed. The memory card becomes the default location for storing pictures. However, the PIF frames and sound files stored in the camera's internal memory are still available.
9/13/2005 10:32:47 AM • Epson PhotoPC... • Answered on Sep 13, 2005
Is the camera DPOF compatible?
Yes!
9/13/2005 10:31:51 AM • Epson PhotoPC... • Answered on Sep 13, 2005
Is all of the camera's internal memory available for storing images?
No. Aproximately 9MB of the camera's internal memory is used to store PIF frames and sound files.
9/13/2005 10:30:51 AM • Epson PhotoPC... • Answered on Sep 13, 2005
How can I print multiple images on one page using the direct print feature?
Follow these steps: 1. Connect the camera to the printer. 2. Turn on the printer. 3. Turn the Mode dial to Playback mode and turn the camera on. 4. Press the (+) button on the camera. 5. Press the up or down button, choose Select images, then press the OK button. Note: If you see the message “Use previous print order selection?” select No, then press the OK button. 6. The images display as thumbnails. Select the first photo to print using the < or > button. 7. Select the number of copies to print using the up or down button, press OK. The screen displays the print settings and the number of copies selected. 8. Press the MENU button to return to thumbnails. 9. Repeat steps 6, 7, and 8 to select additional images. 10. After you select all the images to print, press the MENU button. 11. Press the up or down button to select Print an Album. 12. Select the number of photos per page using the < or > button, then press the OK button. Note: To determine the maximum number of images your printer can print per page see the table below. If you select more images per page than the printer supports, the camera will display the error “This function is not available”.
9/13/2005 10:29:58 AM • Epson PhotoPC... • Answered on Sep 13, 2005
Can I delete the PIF frames and sound files stored in the camera's internal memory?
Yes. There are two ways to delete the PIF frames and sound files from the camera: * Connect the camera to a computer and drag the EPUDL folder and EPSOUND folder to the recycle bin or trash can on your computer. * Format the camera’s internal memory. Note: If you plan to restore the sound files to the camera’s internal memory, save a backup copy of the EPSOUND folder before you delete the folder.
9/13/2005 10:25:49 AM • Epson PhotoPC... • Answered on Sep 13, 2005
The camera does not take a photo when I press the shutter button.
Check the following: * Make sure the battery or batteries have power and are correctly installed. You may need to replace the batteries. * Make sure the power is on. The camera may have turned off automatically to save power. Press the POWER button to turn the camera on. * Make sure the Mode dial is set to the correct mode. The shutter button will operate when it is set to Manual mode, Automatic mode, Continous shooting mode and Video mode. * Check the number in the lower left corner of the Camera’s LCD screen. If the number is 0, the memory card (or internal memory) is full. Copy the photos to a computer and delete them from the camera.
9/13/2005 10:25:02 AM • Epson PhotoPC... • Answered on Sep 13, 2005
2answers
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
9/13/2005 10:23:04 AM • Epson PhotoPC... • Answered on Sep 13, 2005
2answers
The LCD screen is hard to see
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
9/12/2005 1:33:05 PM • Epson PhotoPC... • Answered on Sep 12, 2005
Epson PictureMate printer not pulling up the photos.
Although the photos are saved as .JPG, is there an issue with the physical size of them ? Perchance, should the loaded image exceed the size of the paper loaded, the printer may not be able to print it.
9/10/2019 7:27:57 AM • Epson Cameras • Answered on Sep 10, 2019
How can i downloaded epson l110
Download what ? Manual ?
1/9/2018 12:46:33 PM • Epson Cameras • Answered on Jan 09, 2018
I have Epson PowerLite 77c.
Hi, go to the link below to download it :-) jn3v16
7/3/2014 3:49:09 PM • Epson Cameras • Answered on Jul 03, 2014
I have an epson 500 picturemate. Bought new camera
No you don't have to buy a new printer :-) for a few pence /cents you can buy an adapter from eBay.
7/3/2014 3:43:57 PM • Epson Cameras • Answered on Jul 03, 2014
Blurry right side
You may have a finger getting into the area in front of the lens.
10/21/2013 7:32:47 PM • Epson Cameras • Answered on Oct 21, 2013
I have the Nikon D7000, is there a way to take
The D7000 doesn't have wireless capability on its own. However, depending on how your printer is configured, you could use an Eye-Fi card to send your pictures to be printed.
3/5/2012 6:26:35 PM • Epson Cameras • Answered on Mar 05, 2012
Epson PhotoPC L410 Digital Camera Logo
11 questions posted
Top Epson Cameras Experts
ZJ Limited
ZJ Limited
Tony Parsons
Tony Parsons
August Brown
August Brown
Are you an Epson Camera Expert? Answer questions, earn points and help others
View Most Popular
PhotoPC Epson
  • PhotoPC Epson
Most Popular Question
lcd screen hard see
  • Cameras
