20 Most Recent Symbol LS-1006 (ls1006i0001900z) Handheld Questions & Answers
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes. This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93, Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
3/9/2015 11:55:10 AM • Symbol LS-1006... • Answered on Mar 09, 2015
What the IE symbol in Isuzu meter board?
'Internet Explorer' probably has a problem. Use Chrome or Firefox.
3/9/2024 3:45:01 AM • Symbol Computers... • Answered on Mar 09, 2024
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
  1. Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
  2. Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
  3. Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
  4. Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
3/3/2023 10:16:08 PM • Symbol Computers... • Answered on Mar 03, 2023
2answers
How to type degree symbol on mac
There are a few different ways to type the degree
  1. Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
  2. Use the character viewer:
  • Go to the Edit menu and select Emoji & Symbols.
  • In the search field, type "degree".
  • Double-click the degree symbol to insert it into your document.
  1. Use the ASCII code:
  • Press and hold the Option key and the Shift key.
  • Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
1/6/2023 8:09:59 PM • Symbol Computers... • Answered on Jan 06, 2023
2answers
British Gas T4 RF My battery symbol is flashing. Do I need to change the battery?
no info generic answer --have battery and alternator tested--check belts and connections
1/5/2023 8:41:08 PM • Symbol Computers... • Answered on Jan 05, 2023
Videocon ac remote not working
Hi, Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included. You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
7/27/2022 11:25:03 PM • Symbol Computers... • Answered on Jul 27, 2022
How do I get firmware or a plugin for Zebra Symbol LS4278 Scanner - Model LS4278-SR20157ZZWR
Use " Scanner update utility " to update the firmware. after this try to configure scanner with " 123 scan utility " https://www.zebra.com/us/en/support-downloads/scanners/general-purpose-scanners/ls4278.html#pageandfilelist_895c
5/20/2022 10:41:28 AM • Symbol Computers... • Answered on May 20, 2022
Typewriter Brother AX-22, When typing, a wrong symbol showed up.
I lack access to the keyboard. That said, according to the manual on page 13, depressing the code button and holding it down while pressing another key will access the green symbol on that key, part of an alternate set of characters. It you see a green / mark on a key, you have your answer. https://www.manualslib.com/manual/376756/Brother-Ax-22.html?page=17#manual The page 17 you see in the link pulls up page 13 in the manual.
12/19/2021 6:06:53 PM • Symbol Computers... • Answered on Dec 19, 2021
I have a te 2200 and need to change currency symbol from euros to pounds. Please help the user manual isn't much help
The CE key is a toggle between foreign currency and local currency at a preset exchange rate. That is, it converts both ways. If this does not help, you may have to consult casio support for your region.
12/22/2020 8:36:34 PM • Symbol Computers... • Answered on Dec 22, 2020
tip
IPhone Google Maps not Talking
On iPhone go to Settings. Scroll down to Maps and touch. Scroll down to Driving and Navigation and touch. Scroll down to Navigation and Voice Volume and ensure that Loud Volume is checked. Push the upper volume button on the side of the iPhone to max ring volume. But this is not all. Here is the secret, which it took me a long time to find out from an obscure post on the web. Open google maps and choose your location (location services must be on) as origin and some other place as destination. Touch Start (varies by screen, whether you have chosen the little angle arrow for directions or are on another screen -- no matter). Now here is the key part of it. Immediately after touching Start, push the volume up button on the side of the iPhone and keep pushing. A little volume symbol will appear on the screen with ascending bar, and you'll start to hear the voice. The problem is that the volume button works with google maps ONLY when the google maps voice is speaking (which happens for a very short time immediately after you touch Start, so you have to be quick). At other times the volume button controls ring volume, not map voice volume. Since you can't hear the google voice in the first place, you don't know when to push the volume up button to make it louder, and you can't change the volume unless the voice is speaking. The above procedure worked for me after I tried many other things and also heard from some sites that it was the new operating system that had disabled the maps voice, which is not the case. I am using an iPhone 5C with IOS 10.3.3. This may not work with other phones. Not responsible for errors or omissions. Your results may vary. Good luck to all.
on Dec 31, 2019 • Computers & Internet
Hi there, does anyone has Fusion driver 2.0 for Symbol MC3090, since Id updated to Fusion 2.57.0.0.025B from Zebra webpage and from there on my wireless network didnt work. Thanks in advance.
a true relic, 16 years old for sure last one sold new 2011, support ended 2016 (missed the boat) 2004 first one. https://www.zebra.com/us/en/support-downloads/mobile-computers/handheld/mc3000.html what PC, name it and the OS, windows xp to w10., what? you posted to computers so..... it is a UPC bar code scanner , as seen in STORES check out. we have no idea what wireless network any one has, until told. my wild guess is you are not at home. only the maker support this old UPC scanner wireless wifi is
WLAN: 802.11a/b/g WPAN: Bluetooth only. and only if opted new. the manual states Windows Mobile 6.1 or Windows CE 5.0 device: no story told, found this in a dumpster or garage sale>? first time ever to attempt to get it to work? what is you host, A PC? or what? running what os The do not have drivers for most popular OS, sorry. and not now. all there is , is here. https://www.zebra.com/us/en/support-downloads/mobile-computers/handheld/mc3000.html#pageandfilelist_4c86
12/19/2019 1:20:26 PM • Symbol Computers... • Answered on Dec 19, 2019
I am trying to connect my Luxor smart tv to the internet over a wireless connection, there is an underscore in the network name but I cannot type one, I’ve tried holding the 0 button down on the remote because there is an underscore symbol on it but this doesn’t work, I even bought a new remote but still no joy. Do I need to get a keyboard?
most likely on the keyboard you get on the screen in the left bottom corner will be an alternative symbol option key if not you might have to change the bbid on the wi fi router and all your other devices connected to it by removing the underscore
10/5/2019 10:09:57 PM • Symbol Computers... • Answered on Oct 05, 2019
I have a triangular symbol in the icon next to the internet symbol what is it
A screens hot of it would really help. And what Operating system and version are you running. These information will help the troubleshooting in solving the issue. hoping to hear from you soon, as I will love to render my assistance.
6/27/2019 10:28:09 AM • Symbol Computers... • Answered on Jun 27, 2019
Symbol barcode scanner wont read hyphen
Hi, That's a very specific question. Without knowledge of all your setup, scanner make/model, the reading software and its config there's not really anyone other than a specialist can help you with. Sorry.
6/2/2019 5:42:29 PM • Symbol Computers... • Answered on Jun 02, 2019
0answers
Symbol LS-1006 (ls1006i0001900z) Handheld Logo
2 questions posted
Popular Products
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
cannot read bar code
