20 Most Recent
Apple iPod touch 4th Generation MP3 Player Questions & Answers
Unlock a disabled ipod
Hold power button and home button at the same time untill the screen goes black or shows to connect to Itunes. Restore it from there
How do I fix my ipod that says disabled try agean in 23380670 minutes
you will have to either erase and backup your ipod or you will have to go into recovery mode.
power off and then as you're plugging into your computer hold the home button down until you see the itunes screen. Itunes should alert you that it detects a device in recovery mode. click ok and then restore.
Computer wont recognise ipod to sync
It may be a problem with the cable you're using. You should try another cable and see if that makes any difference first.
Let us know if that helps.
~Thank you.
Why won't my camera work in my Ipod touch 4th generation?
you might not have any memory left on your iPod. I have to same problem with mine some times I have to go and delete some stuff and then I starts to work again. so try deleting some stuff like pictures you don't like or some music you don't listen to anymore
IPod touch 4 sound output problems
Try using a very fine cloth to get into the headphones port and the charging port. If all else fails, you will probably have to take it into the Apple Store :D
