20 Most Recent
Archos 30c vision MP3 Player Questions & Answers
Transfer music to i Tunes
mavericks is finicky. what machine can you connect it to? try reinstalling iTunes. be sure to back up your music and files first.
Cant delete files or photos from mp3 player
If you have or can get a lend of another cable for it, try it incase your cable is bad.I have went through 5 for my 604 as they just stop working out of the blue and getting a new one sorted it.
How to download music
When you connect the MP3 player to yourcomputer with the supplied USB cable then computer detects the player as anexternal storage device or a Removable disk, you can then view the folder onyour MP3 player. Open the music folder and create a new folder on the playerexactly the same way you create a folder on your computer's hard drive. Toorganise your music, make a folder name with the name of the music album andplace the album's MP3 files in this folder, then copy the mp3 files from thecomputer into this folder.You will then be able to select the music you want to play by the music albumfolder.To delete a filefrom your MP3 player, connect the supplied USB cable to your player and thenplug it into the USB port of your computer.The computer will detect your player then click on this device to view thefiles, you can then click on the music file to highlight the file and thenpress the Del key to delete the file off your MP3 player. MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Archos 605 wifi lcd screen keep turn off
If your Archos 605 WiFi LCD screen keeps turning off, it may be due to a few reasons:
- Battery issues: If the battery is low or has a poor connection, the LCD screen may turn off intermittently. Try charging the battery fully and checking if the problem persists.
- Power settings: The device may be set to turn off the LCD screen after a period of inactivity. Go to the device settings and adjust the power settings to keep the screen on.
- Firmware issues: If the firmware is outdated or corrupted, it may cause the LCD screen to turn off. Try updating the firmware to the latest version available.
- Hardware issues: If none of the above solutions work, it may be a hardware issue with the LCD screen or its connection. You may need to take it to a professional technician to diagnose and fix the problem.
I hope this helps!
