20 Most Recent
Kingston Ssdnow Snv425S2128gb 128 Gb Internal Read 200mbps Write 160mbps Hard Drive Questions & Answers
SNV425S2128gb
The driver should be built into the OS. If you can't access the SSD from Windows Explorer, you may need to format the drive or it is a failed unit. If you have connected the drive to a SATA port on your motherboard, you should check if the drive shows up in your BIOS (assuming good cables and power). Next go to the Disk Management tool with an administrative user account. (Click Start > Control Panel > System and Security > System > Administrative Tools. Then go to Computer Management and the Disk Management tool. Alternatively, choose the Command Prompt (under Accessories) with a right click and select Run As Administrator. Then type in diskmgmt.msc and press Enter.) Check if the drive is listed there. It will be disk 1, if you have the usual single hard drive. If it has unallocated space, you can format the drive and give it a letter name here.
If you don't have the drive listed here, try different power cables from your power supply and SATA cables. If it still doesn't respond, RMA the drive if it is under warranty.
I hope this helps.
2261 pram
2261 pram
It's identified as 2261 pram usb device and not working
11/18/2014 1:23:34 PM •
Kingston...
Answered
on Nov 18, 2014
How to fix microsd card?
lol , maybe the best way is to buys a new one , but if you have a good one and it's cost much so tell us the name of it to see what we need to do
9/28/2014 2:40:53 PM •
Kingston...
Answered
on Sep 28, 2014
