The so called experts are really not experts at all and have all diagnosed this problem incorrectly! The problem with your motor is that the Limit switch has either one of the contacts that shut the motor off ..came off the plastic housing ! These adjustable nylon screws clip to the housing that they are secured to sometimes the nylon adjusting screw pops off or it,s copper stop contact has popped off ! This contact or screw whichever has popped off can be snapped back on and in order to do this you would have to take the cover off , Note if your machine is older then 4-5 years it will have these adjustment screws that are called up limit and down limit adjustments on the side of the steel outer casing , anything newer then that has automatic sensing adjustments and will not have these turn screws for manual adjustment !Once the case is removed inspect the limit switch for eithe the contact coming off or the screw itself , simply snap it back in place and with the cover off do your adjustment for the limit of how high or low you want your door to be set at , This adjustment can also be found in the owners manual as well as on line ! Hope this helps you and yes this is the correct diagnosis for your problem , a stripped gear would have absolutely nothing to do with a motor that constantly runs since the sensor that makes contact with the machine when it hits it,s limit automatically stops the motor and since yours keeps running your problem is 100% positive with the limit switch!
When buttons stick on a keypad that's because their getting worn out , you need to use a different set of numbers that are not the same as the worn out ones! If I used the numbers 1-2-3-4 everyday for years at some point 1 or a few of the numbers will start to act up so what I suggest to all the customers is just change the numbers unless you like spending $49.99 on a new keypad ! This way you will save money and get to use the numbers you never used before! Now that's Smart! program any other numbers like 5-6-7-8 or 7587 or any combination you like except the numbers that were giving you problems ! Hope this helps you Sincerely Glenn
IF THE MOTOR IS JAMMED (JUST HUMS) LOOSEN THE CHAIN AND ADJUST THE LIMITS AND TIGHTEN CHAIN.
IF THE MOTOR ACTUALLY RUNS AND THE CHAIN DOES NOT MOVE THE DRIVE GEARS NEED TO BE REPLACED. THEY SELL A KIT THAT INCLUDES THE BUSHINGS AND SHAFT. DO NOT BUY THE SMALLER KIT AND DO NOT REPLACE ONLY ONE GEAR (THE OLDER WORN GEAR WILL CHEW UP THE NEW GEAR) THIS MAY BE WHAT YOU HAD DONE - IF SO CALL THE SERVICE GUY THAT DID THE POOR REPAIR AND HE SHOULD REPLACE BOTH GEARS UNDER HIS SERVICE WARRANTY. ANYONE WORKING ON THESE SHOULD KNOW BETTER.
GOOD LUCK.
STEVE
Question edited for clarity.
Question moved from Cars and Trucks category.
Look at the corners of the doors that hold the aluminium frame together and if it is a modular door, tighten them up. If it is a solid door, adjustment can be made by shimming behind the bottom hinge with a piece of cardboard. This will move the bottom out and up.
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button.
http://www.youtube.com/watch?v=7CqMy2UfG9k
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube.
If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
At NHK Tiling, our tiling process has been perfected over the years to give you the best results possible. Our Expert Tiling Service is perfected for a range of applications, styles and functions. Whether you require contrasting grout to make a statement with your kitchen splashback, or you need a Professional Tiler for tiling your swimming pool, NHK Tiling is the ideal choice for you.
https://www.nhktiling.com.au/
GRANITE WAREHOUSE is a privately owned Western Australia business specializing in the wholesale of Granite, Marble, Limestone, Sandstone and our line of engineered stone, Stellastone, in slab form suited for the fabrication of kitchen and vanity benchtops as well as other building uses.
Granite Warehouse was founded in 1995 by Tindaro (Tony) Tomeo to fill a need in the local Western Australian market for quality natural stone. With more than 40 years experience in the building industry, specializing in cabinet making and kitchen fit-out, Tony, with wife Susan and son Mark, built Granite Warehouse into the well-respected business it is today.
With Tony and Susan's retirement, and in the best family tradition, Granite Warehouse has been taken over by Mark Tomeo who continues to develop the business to fill best the needs of those wanting to enjoy the beauty of stone installed to their home or business.
https://granitewarehouse.com.au/
