20 Most Recent Gateway DC-M40 Digital Camera Questions & Answers
manual
Samsung S1065 digital camera. Won't witch on. Len
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
12/9/2012 8:31:42 PM • Gateway DC-M40... • Answered on Dec 09, 2012
3answers
Samsung S1065 does not turn
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
11/14/2011 6:45:59 PM • Gateway DC-M40... • Answered on Nov 14, 2011
Where can i buy cf
You should be able to buy CF cards at just about any camera, department, electronics, or office-supply store. Some drugstores and supermarkets carry them as well.
2/12/2011 10:08:00 PM • Gateway DC-M40... • Answered on Feb 12, 2011
My samsung s1065 camera has frozen, new batteries
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
5/8/2010 11:19:23 PM • Gateway DC-M40... • Answered on May 08, 2010
I have the same camera at one year old and I have
http://www.youtube.com/watch?v=TmOPab5E4bw
WATCH MY VIDEO THIS MAY HELP
2/12/2010 3:21:27 AM • Gateway DC-M40... • Answered on Feb 12, 2010
2answers
Gateway DC-40. I attempted to format a new 4GB
Remove the Card and see, if that would help the situation. Update the Firmware, if available.
Let me know the progress, so we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/16/2010 4:53:41 AM • Gateway DC-M40... • Answered on Jan 16, 2010
2answers
Samsung s1065 beeps 3 times nothing else. only
One of the 4 conditions a-batteries are inserted incorrectly b-batteries have died and need to be replaced c-you have selected the wrong battery type option on the Setup2 menu d-your camera is malfunctioning and needs servicing.
1/2/2010 10:14:58 PM • Gateway DC-M40... • Answered on Jan 02, 2010
2answers
Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
1/2/2010 10:02:01 PM • Gateway DC-M40... • Answered on Jan 02, 2010
2answers
Camera will not work
Using the wrong cable can certainly damage a camera.
You don't say what "inoperable" means. I have sold and serviced many digital camera over the years. Dropping a camera will often result in damage to the lens assembly causing blurry/distorted pictures or the lens will not extend or close.
If the camera is completely dead or fails to boot then you probably used the wrong cable or connected it incorrectly and fried the internal electronics. This particular Gateway/Samsung camera can be fried if you connect or disconnect the USB cable while the camera is power on.
Sounds like you owe your friend a new camera.
9/4/2009 11:03:05 AM • Gateway DC-M40... • Answered on Sep 04, 2009
I am told that I have a shutter problem and it
Unfortunately this might be right. Usually the replacement part alone is worth more than the entire camera new. That's very common on quite a few electronic devices. One of the worst examples of this I've seen was was a quote for a $200 replacement printer head for a $49 printer. As well you can expect to pay labor on top of the actual parts cost so the repair cost quickly adds up. I would check for warranty if any and if you can't get that covered look at a new camera. Like most digital devices the newer ones tend to be as cheap or cheaper with better functionality. So for the same cost of repair or very close you could just get a new camera that is better (and with warranty)
9/4/2009 1:46:32 AM • Gateway DC-M40... • Answered on Sep 04, 2009
S1065 BEEPS 3 TIMES THEN NOTHING
IT USUALLY DOES THAT WHEN THE BATTERIES ARE DYING AND IT SHUTS DOWN - HAVE YOU TRIED USING RECHAREGABLE BATTERIES - THEY LAST A LITTLE LONGER.
6/18/2009 3:25:42 PM • Gateway DC-M40... • Answered on Jun 18, 2009
USB Error message appearing
change the port or cord
6/18/2009 3:24:30 PM • Gateway DC-M40... • Answered on Jun 18, 2009
Shut down prematurely
It turns out that the problem was the batteries. I put some good ones that I had in the camera and it started working just fine. Even though the others were showing that they at least partially working, maybe just not enough juice to really work. Anyway, with just about any problem - try new batteries first and see if there is any change or improvement.
3/24/2009 10:43:35 AM • Gateway DC-M40... • Answered on Mar 24, 2009
Flash card 64 mb
The DC-M40 will take up to a 512mb CF card. You may have to format the card. Do this from the camera's menu. If that doesn't help, the card may be defective.
1/5/2009 7:34:55 AM • Gateway DC-M40... • Answered on Jan 05, 2009
Gateway DC-M40 Digital Camera Logo
24 questions posted
Top Gateway Cameras Experts
ZJ Limited
ZJ Limited
Renee Knafel-Bullock
Tony Parsons
Tony Parsons
Are you a Gateway Camera Expert? Answer questions, earn points and help others
View Most Popular
Gateway Cameras
  • Gateway Cameras
Most Popular Question
samsung s1065 camera frozen new batterie
  • Cameras
