20 Most Recent
Samsung UN46D6050 TV Questions & Answers
Factory reset
Salve TV Samsung T200hd problema volume si alza ma si abbassa da solo cosa fare.
1/10/2019 3:54:58 PM •
Samsung...
Answered
on Jan 10, 2019
How do I do a factory reset on my jmb tv as I can't get anything just no signal and no sound
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
10/27/2017 2:02:56 PM •
Samsung...
Answered
on Oct 27, 2017
Samsung un46d6000sf tv not turning on standby light blinks. Need help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
6/27/2016 8:17:11 PM •
Samsung...
Answered
on Jun 27, 2016
Best picture settings
Best picture is nothing but the picture which is comfortable to your eyes and pleases you to watch. You can either select a suitable picture mode like standard, dynamic or vivid or you can set the color, contrast, brightness and sharpness according to your liking.
1/16/2016 6:45:20 AM •
Samsung...
Answered
on Jan 16, 2016
Language menu
Hi Fernando..Yes your TV can support Spanish language.It is easy to change your menu language to Spanish.Please follow these steps to change into Spanish.1)Press the menu button using your remote.2)Wait for the menu to be displayed.Once the menu is displayed click the language menu from the display.3)You can find all the languages listed on the menu.4)Select and Press OK to activate your language.5)Press Enter and Exit.Enjoy watching your TV with Spanish menu..
3/23/2013 2:15:34 PM •
Samsung...
Answered
on Mar 23, 2013
No picture from un46d6050
if it is LCD you have faulty t-con board if you have backlight if not inverter board.if plasma your y-sustain board is defective that need to be replace in able to fix the problem.
11/4/2012 12:40:22 PM •
Samsung...
Answered
on Nov 04, 2012
