Its time to tune-up your laptop through following these tips given below:-' Disinfect your system using some reliable antivirus program.' Run disk clean up (start > programs > accessories > system tools > disk cleanup.)' Disable background services.' Fix OS registry errors with properly with PCFresher.' Defragment the registry if needed.' Uninstall all programs & software's and download latest versions of them.Thanks
Right click on the Desktop to bring up Display Properties - Click on Appearance tab - then click on Effects button - and then tick Use large icons box - click OK - Click Ok in Display Properties to make the change.
First, you will need to make sure your internet provider is not the problem, use a second computer on the same connection to be sure. If you are on wireless open the window on the wireless icon, click on repair and windows will fix the connection in most cases. If on ethernet direct connection to the modem sub another cable to make sure the link is solid.
I'm not an Acer expert, but I'm curious where on the laptop this seems to come from... hold your hand on it or your ear to the top... can you determine where the humming comes from? The only thing I could think of is the the HDD, but that should not spin when its off (maybe its in hibernation?). If you cant determine where its coming from unplug it and remove the battery, wihch should stop it. Plug the battery back in and see if it comes back while the laptop is still off.
You can try, if you have your notebook cd, to install from original cd from supplier. If you don't have the cds you should download the drivers from producers website from another pc, copy them on a usb key and install the drivers on your laptop from there
Question edited for clarity and toss in a few CAPS.
Question moved to Acer Aspire category.
There a few issues that can cause this, the obvious one is that the battery has failed internally, but it can also be a charging software issue. Try this. Unplug from the mains supply. Remove the battery. Leave the computer for 2 hours. Press and hold the power button for a full 2 minutes. Replace the battery, plug back in, count to 10 and power it back up.
Has the motherboard battery ever been changed? They are critical to the health of the motherboard and the machine in general.
what password computer or outlook
Reset an Outlook password to keep your program secure.
A
Microsoft Outlook password keeps your email account secure from unwanted
intrusion.
When you wish to reset your Outlook password, you must
perform a multistep process to change your password first with your Internet
Service Provider (ISP).
The password with your ISP mail server must be the same as
the password you set in your Outlook program in order to send and receive
emails.
Call your ISP and request a new password for your account.
Write down the password after you receive it to ensure you
do not forget it.
Open your Outlook program, click the "Tools" tab
and then select "Email accounts."
Select "View or change existing email accounts"
and then press "Next."
Highlight the email account you wish to change (if you
have more than one email account) and press "Change."
Enter the new password you just received from your ISP
into the appropriate fields (entering it twice).
Place a check mark beside "remember password" if
you want Outlook to remember your password each time you log in.
Click "Test Account Settings" to make sure your
account works with the new password.
Press "Finish."
I forgot my Outlook password
http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
If you have no internal hard drive installed you won't get it to work correctly as the hard drive is where the data is stored for the operating system.
Estimado Carlos,
Cuando la PC se apaga poco tiempo despues de terla prendido puede ser una senal de sobrecalentamiento del procesador. Si es una PC desktop, puedes verificar si el disipador de calor de aluminio y su ventilador estan colocados correctamente sobre el procesador y si el ventilador esta' funcionando. Si es una laptop, debes verificar si cuando la prendes el ventilador de las rejitas de ventilacion esta' suenando. Un ventilador que este' parado o con baja rotacion puede ser una de las causas del sobrecalentamiento. Pero, en los dos casos, si no es problema del ventilador del procesador, lo que hay que hacer es lo siguiente:
1 - Desarmar la computadora, y sacar el disipador de calor com mucho cuidado de sobre el procesador;
2 - Limpiar bien entre las ranuras del disipador de calor, sacandose todo el polvo y suciedad del mismo ya que el polvo ayuda a mantener el calor y sobrecalentar el procesador;
3 - Limpiar muy bien las rejillas de entrada/salida de aire, sacandose todo el polvo y suciedad,
4 - Rearmar el disipador sobre el procesador, pasando entre ellos una delgada camada de pasta termica plateada, que se puede comprar en tiendas de suminsitros y partes de computadoras (NOTA: no instale el disipador sobre el procesador sin pasar la pasta termica, porque podra' seguir sobrecalentandose);
5 - Rearmar la computadora.
Caso usted no tenga facilidad en armar y desarmar la computadora, seria bueno contactarse con un tecnico de su confianza para hacer ese trabajo para usted.
!Espero que esa respuesta pueda haberle sido util!
PD.: Como ese sitio web solamente accepta caracteres en Ingles, la acentuacion no puede ser utilizada normalmente...
Saludos,
Miguel Luiz Martins
OucH no acer real model PC told at all wow hard nut to crack that, I sure can not guess that ...The case told only helps if power on button is wrongor the PSU is wrong. I moved this to acer forum. as the mobo matters.Q1;never worked before by you,? this acer mobo by you?or found it used and dead.? used mobo come good bad or a wreck. (history not told , as in when did fail)the acer.com is the place to look first. for manuals. not told what GPU are you using onboard vga or GPU card or what?All fans spin ? CPU and PSU????if using GPU card that has fan, does it spin too??if case fans do they spin?DoeS DVD tray eject (button hit)?DOES PC beep or flash LED codes?Q2;What VIDEO port class is this "connection"is it:vga, hdmi, dvi or DP ports which one, and where is it? For now only use (if has one) use the VGA port on the mobo , no PCI cards in slots., NO HDD, AND NO DVD DRIVE (JUST UNPLUG THEM FOR NOW) ALL USB THINGS UNPLUG, KEYBOARD LEAVE THERE.MEMORY :pUT 1 stick of ddr RAM only in bank0 channel "A"CPU socket pins bent as seen on ebay endless and sad. below is me guessing what Acer you have.and find this, Acer/GATEWAY ZX4951 or ASPIRE Z3100I read the GW manual check jumpers.the PSU needs 2 power cables to the mobo.4pin power and 24pin (or 20 on legacy)or mobo will be dead. why mess with ACER. (they have no service manuals)put an Asus or Gigabyte mobo there and end this ACER pain,post a photo of the mobo and we can guess what PC it came out of, .......
