20 Most Recent
T-Mobile MDA III Pocket PC Questions & Answers
I cant get the back light to come on
Possible that the circuit has a break into this section / the lights are not trigggered on / fault in the hardware.
Reset the PC to default and see if there is any change. If not it can be fault in the board.
Advice that the job be refered so as not to tamper without the right equipments.
How to get/convert English OS for PH20B T-Mobile MDA
You need to reflash ROM. Operation is a bit risky, if you don't follow the procedure. Consider upgrade to WM5/WM6.
All the information is on the below Link -
http://wiki.xda-developers.com/index...=HTC_Blueangel
Remeber about fixing you keyboard layout in registry
Good Luck
It has blocked all ikons, programs and
you need to exit every program after you use it.your phone is running to many applications.just soft reset it.then satrt menu---settings---memory
and u'll understand.i suggest u download o2 menu button to close programs.
Manuale
Here we go.
I found this for you. Pls leave good rating!
Changing from german language to french language
Thanks
Changing from french language to english lauguage
Good Luck
Thanks
My t mobile doesn't recognise simcard
assuming the phone is a t mobile branded phone(if not it won't work) try some rubbing alcohol on the little contacts on the sim card. if still nothing then the card is shot.
