20 Most Recent Electrolux EIDW5905JS Dishwasher Questions & Answers
Water did not pump. Now will not start no display lights iluminated
Hello friend, thank you for your post! I understand that your Electrolux dishwasher is not pumping water out and the display will not light. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the problem, you may need to replace the control panel or the drain pump. Since it could be anyone of these underlying issues I would suggest seeking assistance from a professional technician this will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
2/26/2016 4:34:14 PM • Electrolux... • Answered on Feb 26, 2016
Electrolux 24 in. Diswasher
Hello Darlene, thank you for allowing me to assist you!
The "ER" code that keeps appearing on your Electrolux dishwasher stands for a Membrane Switch Failure. Normally that means that your control board has detected a stuck key or key pressed for more than a minute. That could possibly be an issue with your keypad or main control board. I would recommend having a technician come out to your home to properly diagnose and repair your dishwasher. I hope this is helpful. -Matt
8/6/2014 3:06:51 PM • Electrolux... • Answered on Aug 06, 2014
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend, I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty. 2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed. 3)Check to see if drain hose is kinked. 4)Make sure cycle is complete, not in a pause. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
7/8/2014 12:52:10 PM • Electrolux... • Answered on Jul 08, 2014
Why does my dishwasher not drain completely at the end of its cycle.
7/8/2014 12:50:47 PM • Electrolux... • Answered on Jul 08, 2014
Anti flood reset on a Electrolux washing machine
See page 28 Solution to Common Problems in user manual for help User manual Electrolux ELFW4222AW (English - 32 pages)
1/20/2024 1:26:42 PM • Electrolux... • Answered on Jan 20, 2024
2answers
Electrolux dishwasher wont stop draining
Hi I think I’ve got the same problem that the overflow plastic tray didn’t move down due to dirt. See pic. Anybody an idea how to open/ remove and clean this tray on Electrolux dishwasher?
11/12/2023 8:46:46 AM • Electrolux... • Answered on Nov 12, 2023
Parts of electrolux esl6201lo dishwasher presure switch
The pressure switch in a dishwasher, like the Electrolux ESL6201LO, is a component that helps regulate water levels and prevent overfilling. It's an important part of the dishwasher's water management system. However, I must clarify that specific part numbers, designs, and configurations can vary by model and production date. If you're looking for parts or information about the pressure switch for your dishwasher, I recommend the following steps: 1. **Consult the User Manual:** Check the user manual or documentation that came with your Electrolux dishwasher. The manual might provide information about parts, part numbers, and troubleshooting for your specific model. 2. **Electrolux Customer Support:** Reach out to Electrolux's customer support or service center. They can provide you with accurate information about the pressure switch and help you find the correct replacement part if needed. 3. **Online Appliance Parts Retailers:** Websites that specialize in appliance parts, such as RepairClinic, AppliancePartsPros, and eReplacementParts, often provide diagrams, parts lists, and compatible replacement parts for various appliances, including dishwashers. Search using your model number to find the pressure switch or related parts. 4. **Local Appliance Repair Shops:** Local appliance repair shops often have access to a variety of appliance parts, including pressure switches. They might also be able to assist you in identifying the correct part. 5. **Electrolux Authorized Service Centers:** Contact authorized service centers for Electrolux appliances. They should have access to genuine replacement parts and can provide professional assistance. When searching for parts, always make sure you have the correct model number and, if possible, the part number of the specific component you need. This information will help ensure that you get the right part for your dishwasher model.
8/20/2023 2:29:00 PM • Electrolux... • Answered on Aug 20, 2023
Electrolux ESL5201LO dishwasher beeping fault -
8/15/2023 10:05:41 AM • Electrolux... • Answered on Aug 15, 2023
Electrolux dishwasher erorr c4
buy the manual or get it fixed? moved you out of cars
2/14/2023 1:13:49 PM • Electrolux... • Answered on Feb 14, 2023
What is error code c13 - Electrolux Dishwashers EHT8ILG8 MODEL
Error code C13 on an Electrolux dishwasher model EHT8ILG8 indicates a problem with the water supply to the dishwasher. The code specifically refers to a problem with the water pressure, which could be caused by a clogged water inlet filter, a malfunctioning water inlet valve, or a problem with the water supply hose. To troubleshoot this issue, first check the water supply hose to ensure that it is not kinked or clogged. Then, clean the water inlet filter and make sure that the water supply to the dishwasher is not restricted in any way. If the problem persists, it may be necessary to call a professional technician to diagnose and repair the dishwasher. Please keep in mind that this is based on general information, the error code meaning may vary depending on the model and brand. It's recommended to check the dishwasher manual or contact the manufacturer's customer service for more specific information.
1/30/2023 12:32:10 AM • Electrolux... • Answered on Jan 30, 2023
Hi, my Electrolux diswasher ESF 45030 is stuck on draining mode
i think that is engaged via a _(i can't think of the word.. it's a points set that works off an electro-magnet) if that got stuck then it will keep the pump engaged in the drain mode.. otherwise it's an issue with the settings.
12/13/2022 4:18:59 PM • Electrolux... • Answered on Dec 13, 2022
Electrolux WT55 Commercial Dishwasher. Hello, after replacing the cycling pump at WT55, dishwasher stops after 30 seconds at both programs.
Question edited for clarity and full 'make model (what it is)'. Question moved from Cars and Trucks category. It is a commercial unit and should be repaired professionally. Help in the link https://www.google.com/search?q=electrolux+wt55+overheating+solution ..
12/6/2022 10:53:02 PM • Electrolux... • Answered on Dec 06, 2022
I have a 7 year old top of the line Electrolux dishwasher and during the wash cycle it stops and beeps (120 time) . Does anyone know if this is a control panel issue?
It could be anything. They have a diagnostic brain that creates beeps or codes, but never hear of one that beeps 120 times. You can try power cycling it. Remove mains power for 2 minutes and try again. If that doesn't fix it you will need a service call. If it is the control board, you may consider a new machine is a better option.
12/2/2022 3:57:09 AM • Electrolux... • Answered on Dec 02, 2022
2answers
Electrolux dishwasher over flows
Hi, Please pour soap and/or toothpaste at the bottom of the washer. This should unclog any drains that the dishwasher uses. And you can also remove any debris present at the bottom of the dishwasher as well. Otherwise, you need to schedule a home depot repair appointment please. Thank you.
11/10/2022 6:37:44 PM • Electrolux... • Answered on Nov 10, 2022
Washer is filling with clean water
Yes, the water inlet valve is leaking and letting water in past a faulty seal. The valve just needs replacing with a new one. They are not serviceable. https://www.google.com/search?q=AEG%2C+Electrolux+%2C+Favourit+parts%2C+water+inlet+valve ..
10/25/2022 1:41:45 AM • Electrolux... • Answered on Oct 25, 2022
Service manual for Electrolux ESF5201LOW dishwasher.
No Service Manual online Parts schematic are normally on the images tab, but not even those for 'W' or 'X'. https://www.google.com/search?q=electrolux+esf5201low+parts+diagram
6/17/2022 12:20:45 AM • Electrolux... • Answered on Jun 17, 2022
Electrolux EIDW5905JS Dishwasher Logo
8 questions posted
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Dishwashers
Most Popular Question
water did not pump now will not start
  • Dishwashers
