20 Most Recent Maytag MMV1164WS Microwave Oven Questions & Answers
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
8/31/2016 12:30:32 AM • Maytag MMV1164WS... • Answered on Aug 31, 2016
E5 error code microwave
On my Microwave it saying e5 on it and it not reheating it self
11/6/2023 8:04:40 AM • Maytag Microwave... • Answered on Nov 06, 2023
Maytag oven will not heat,
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11/9/2021 12:57:09 PM • Maytag Microwave... • Answered on Nov 09, 2021
Maytag Microwave Model MMV4205DB4 door switch wiring diagram
Have you checked inside the microwave? Usually they have the manual hidden in there.
2/23/2021 4:25:49 PM • Maytag Microwave... • Answered on Feb 23, 2021
Maytag (MMV5165AAS) above range microwave won't turn inside light off when door is closed.
Replace the faulty door switch.
1/30/2021 3:03:53 PM • Maytag Microwave... • Answered on Jan 30, 2021
2answers
WHAT DOES IT MEAN WHEN MY MAYTAG MMV4203DS00 DISPLAYS "SE"?
Hi, My research came up with a shorted keypad (shorted key). The part number I came up with was W10258190 this is for stainless. I hope this information helped. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/21/2019 3:08:08 PM • Maytag Microwave... • Answered on Dec 21, 2019
2answers
Hi, I have a Maytag MMV5207BCS. When i plug it in, it asks to enter the time but buttons on the key pad do not respond. Then i get an SE error. It happened in the past but unplugging on/off fixed it.
The SE error code means you have a shorting membrane keypad.
you would need to replace either the membrane keypad or the control panel frame assembly, which comes with a new keypad already installed.
unfortunately, those parts for this model seem to be unavailable. So the only option would be if you can find a used or "New Old stock" part on eBay or at a local or online appliance parts store.
If you can find either of these parts, that will fix your microwave:
DE94-01386S ASY CONTROL-PANEL (STL)
DE34-00233N SWITCH MEMBRANE (BLK)
The support page for your microwave is here, where you can find manuals and a helpful exploded view part diagram.
https://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5207BCS&siteCd=WHRCOM&userType=Consumer
Good luck.
6/30/2019 11:28:47 AM • Maytag Microwave... • Answered on Jun 30, 2019
Maytag microwave turned on and melted glass turntable,
Replace the MW
1/27/2019 11:10:44 PM • Maytag Microwave... • Answered on Jan 27, 2019
How is the diode connects to a capacitor in a maytag microwave mmv5165aas?
The service manual for model MMV5165 is here at my Web site.
12/15/2018 11:15:03 PM • Maytag Microwave... • Answered on Dec 15, 2018
Maytag microwave W11040918 works intermittently, appears to be associated with door closure
Chances are you have an issue with a door switch or door switch mount. See my help files here: http://www.microwavecontrol.com/safety.htm http://www.microwavecontrol.com/disassembly.htm http://www.microwavecontrol.com/doorsw.htm If you need further help, e-mail me through my Web site (above) with your full model number and detailed symptoms.
12/15/2018 10:45:00 PM • Maytag Microwave... • Answered on Dec 15, 2018
Fxtp6
If you have a stargate chassis maybe look near the power cord, and least they are not on the Antares board of my buggy AKZ 430 : Whirlpool Oven AKZ430 goes to F03 mode in couple of minutes even after...
9/11/2018 10:52:54 AM • Maytag Microwave... • Answered on Sep 11, 2018
How do I change the language on my maytag microwave
Find your model's support page here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=&siteCd=WHRCOM&userType=Consumer Then enter your full model number in the "Search again" box.
6/7/2018 10:52:43 PM • Maytag Microwave... • Answered on Jun 07, 2018
Maytag MMV1164WS Microwave Oven Logo
5 questions posted
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
maytag model mmv1164ws when turn makes
  • Microwave Ovens
