20 Most Recent
Bunn CWTF35 Questions & Answers
Bunn coffee maker, no hot water
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
1/15/2015 3:27:40 PM •
Bunn CWTF35
Answered
on Jan 15, 2015
Have a Bunn CWTF, when the switch is pushed and water begins to flow thru the basket, there is a small amount of water that begins to puddle on top of the left tank (right does it also, but less).
Leaking from top of tank; Call for service as this is an electrical hazard.
*** the following is for information only. ***
* Replace any worn gaskets and silicone tubes.
* There may be cracks in the metal pipes. Hard to see, but there, if you remove the lime deposits.
* check the top tray nut if the gasket to the tank is missing. It's about an 1-1/4" round washer with about a 3/4" hole. Usually made of white silicone rubber. It seals the fill tray to the tank. Leaks often.
* Bunn equipment can last quite a few years (decades?) but the gaskets do get hard and the tank needs to be water tight to work properly. Since this is already an old brewer and you've saved money rebuilding it. Suggest going further by replacing all gaskets. Yes they do need to be snug with no cracks.
Aloha, ukeboy57
How to descale Bunn CW15-APS coffee maker
delime the sprayhead and reservoir drain (in the top) with a deliming spring or a screwdriver. to delime the tank, put a half gallon of vinegar in the top and catch the hot water as it comes out of the sprayhead. leave it sit for about 20 minutes and brew at least 8 times (w/o coffee) or until you can no longer taste vinegar
Bunn water level
What about Bunn water level? Too high? Too low? Not filling? Leaking?
How can I tell if maker is wired for 220 or 120
If its been changed to 220V plugging it into 120V won't damage anything, it just won't work. Replace the plug with a 120V plug end and plug it in. If it works its120 if it doesn't, its either a 220V setup, or you have a blown fuse in the unit/power supply or some other defect.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
