20 Most Recent Samsung LN40D550 LCD TV Questions & Answers
Dish network remote control codes
Hi, my name is Cheri Torres and I work on the Social Media Team at DISH. I would be happy to help you get your DISH remote addressed to your Samsung TV. There are many different codes for each of our different models of remotes. The model number of your remote will be located on the back of the remote at the top, usually a two to three digit number. I will list here for you the best codes for each of our different models of remotes and also the instructions for addressing the remote to the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at [email protected]. remote codes 3.0, 3.1, 3.2, 3.4 IR remotes - codes 680, 738, 516, 655, 667, 833, 897, 500. 5.0, 5.2, 5.3, 5.4 IR remotes - codes 738, 516, 680, 522, 664, 833, 755. 4.0 and 4.4 IR/UHF remotes - codes 738, 516, 680, 667, 833, 858, 897. 6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 738, 680, 516, 505, 755, 833. 20.0, 20.1 IR and 21.0 21.1 IR/UHF remotes - codes 680, 738, 601, 833, 516, 794, 858, 684. Instructions 1. Press and hold down the TV button until all the lights light up on the remote. 2. Enter the 3 digit code for you TV. 3. Press the pound(#) button once. 4. Test the functionality of your TV.
2/14/2020 2:14:20 AM • Samsung LN40D550... • Answered on Feb 14, 2020
What ampheres can be used for samsung LN40D550
  • Triple smart USB ports quickly and easily identify yours mobile devices, to provide optimal charging efficiency.
  • Built-in charging circuitry fully protects devices from any short circuiting,over-heating,over-charging,and over-currents.
  • Provides maximum 2.4A charge speed.Three USB ports offers rapidly charging of smartphones,tablets,and other devices.
  • Adopts highlight design with smooth surface, effectively prevent the scratch,to ensure that the beautiful appearance of the product.
  • Strong compatible:Apple and Android Phones and Tablets,Apple iPad Air,iPad 2,iPad 3,iPad Mini,iPhone 6 Plus/6s plus/7/7 plus Samsung/Nexus and More,HTC,Samsung,Motorola Android Phones and External Battery.
AmanStino Car Charger Quick Charger USB 3 0 3 Port with Smart Sense IC...
11/21/2016 5:38:21 AM • Samsung LN40D550... • Answered on Nov 21, 2016
Image shaking, foggy and looks kinda like static
It will be best to contact any service technician in this case. Gopakumar Gopalan Google
4/20/2014 10:49:18 AM • Samsung LN40D550... • Answered on Apr 20, 2014
Schematic diagram
Schematic diagrams are in PDF, and cannot uploaded by this window. If you wish to get some details,check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
11/1/2013 3:33:32 AM • Samsung LN40D550... • Answered on Nov 01, 2013
How do I get my dvd player to play on my Samsung
go to samsung and you can download the manual from them ok.
10/29/2013 5:50:59 AM • Samsung LN40D550... • Answered on Oct 29, 2013
Ln40d550k1f
Check all the flat connection cables to lcd panel from T'Con board for any loose connections. Re-seat them once and check. If you wish to get more details about these type of faults with Samsung LCD TVs, check this link. There is illustrations to these type of faults and descriptions.
2/7/2013 12:25:04 PM • Samsung LN40D550... • Answered on Feb 07, 2013
Television does not turn on
I see so many people here with nosound /picture issues:ISSUES:1. If sound main fuse/s are good.2. If no power or standby light check fuse, standby power supply, and look forany signs of damage you can see (burnt parts etc)3. Almost all these SETS troubleshooting consists of checking voltages andtrying to narrow problem down.4. Be safe and if do not know what you are doing do not open set.ANSWERS TO ISSUES:1. RE: fuses---if a blown fuse is found get a good replacement (not the Genericones from like Radio Shack). Many fuses used are special even aside fromamperage. Don't put a higher rate amperage fuse in the set for any reason.2. RE:power supply: if total dead aside from main fuse set uses Standby powerand main power supply (some standby is on separate board but most are combined.Here aside from checking fuses you want to examine all the filter caps to seeif any are puffed up or buldged in some fashion; I attach a photo: top shouldbe (silver metal) perfectly flat and have no brown material coming out on topor bottom---l can give you a description if needed here why they fail---too lowvoltage rating causes them (standby area) to overheat and fail in a average 1-2years= The standby is running 7/24 when set is plugged in.3. Trouble shooting: It consists of the above and then at some point you haveto buy and try a board/s to see which if any fix the issue.4. Safety first---no set is worth getting injured or even killed over.Some additional suggestions:Consider contacting company who made set for information to see if your problemis a common one that their data base has ideas about.Also GOOGLE the model number with either "parts" "problems"or "manual" as a lot of information is available for free.have here only given you the basics but they apply to most sets; depending on your skills if you have specificquestions let me know and I will assist as much as possible.
3/21/2012 4:33:42 PM • Samsung LN40D550... • Answered on Mar 21, 2012
How to conect antena
HelloJust download its user manual. It has all the details. You can download it by any among the following links. If you feel any difficulty in downloading the same, inform me by Fixya comment, along with your email address. I've the manual to your set, and will send a copy of it to you by return mail. As it is a PDF file, I cant send it to you by this window, as it does not allow me to upload any pdf files by it.Copy and paste each link into the address bar of your browser and press enter, if you do not get it as a diret link.static.highspeedbackbone.net/pdf/LN40D550.pdfhttp://www.dataentryjobs.us/67948.htmlwww.abt.com/documents/37614/LN40D550_specs.pdf - United States
2/28/2012 3:15:32 PM • Samsung LN40D550... • Answered on Feb 28, 2012
How to conect antena to samsung ln40d550
static.highspeedbackbone.net/pdf/LN40D550.pdfi think this is so helpfull!!@@tablette tactilepc tablette
2/28/2012 6:03:30 AM • Samsung LN40D550... • Answered on Feb 28, 2012
0answers
I just hooked up my Xbox with and HDMI cable,
Ok, I don't have an XBox360 so I can't get specific but if you can't select hdmi input on the TV then you are probably not getting a HDMI signal. I would check your XBox360 set up to be sure that it is set to output video on HDMI not composit, s-video, or component. You might have to return to the last working setup and monitor so that you can see the menu to make the change.
Hope that helps,
Gil
9/21/2011 1:23:26 AM • Samsung LN40D550... • Answered on Sep 21, 2011
My Samsung LN40D550 Tv will
Manually press channel buttons up(+) or down (-).
9/2/2011 11:43:17 PM • Samsung LN40D550... • Answered on Sep 02, 2011
My samsung ln46b610a5fxza picture started to have magenta and green and red vertical lines appear on the screen and now they won't go away
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
1/16/2018 12:19:22 AM • Samsung LN... • Answered on Jan 16, 2018
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
11/18/2016 3:00:54 AM • Samsung LN... • Answered on Nov 18, 2016
Samsung LN40D550 LCD TV Logo
24 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
schematic diagram
  • Televison & Video
