20 Most Recent Genie KEP1 Universal Keyless Garage Entry System Questions & Answers
How do I change the key code in a Genie 35674R Garage Door Opener UNIVERSAL "Wired" Keypad KEP-1 ?
I know this is an old post but in case anyone else has trouble with it...I just replaced this keypad for the 2nd time in 10 years, it just stops working after years of being exposed to the elements. I've changed the code several times but had a lot of trouble with it today in the new one. What finally worked for me when following the instructions to set the switch to "Set" inside the black box, type in your new code and then press and HOLD the star key for at least 5 seconds. Holding the star key down finally worked after multiple attempts to get it to work. Then set the switch in the black box to "Run" and the door should open after typing in your code and hitting *.
7/11/2020 9:24:34 PM • Genie KEP1... • Answered on Jul 11, 2020
Sun prevents garage door from closing
Swapping the sensors is only a temporary fix. As they get old, they get dirty lenses And/or the ir becomes weaker. The sun only adds to the problem. I suggest replacing the saftey sensors.
4/12/2015 10:03:30 PM • Genie Building... • Answered on Apr 12, 2015
I have a genie 2022 and the remotes will not work.
there should be a red or white button on the back of the opener. hit that button then press and hold button on remote. you should hear two clicks. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_a1f2045feb96cdb4
10/28/2013 11:25:45 PM • Genie Building... • Answered on Oct 28, 2013
Why does my garage door opener skip and not open
bad trolley. replace.
8/6/2013 2:29:21 AM • Genie Building... • Answered on Aug 06, 2013
Genie Garage Door RC Receiver. Where is the learn button for Genie receiver model OHDH390 please?
Question edited for clarity. It doesn't look like that model number is correct 390 is the frequency of the signal. It is mentioned here are part of the regulatory approval process as a much longer number https://fccid.io/B8QOHDH390 The Learn Button is next to the bulb https://www.geniedoor.com/support/programming-instructions/garage-door-opener-remote-programming/ More here https://www.geniedoor.com/support/programming-instructions/ https://www.google.com/search?q=genie+receiver+ohdh390+learning+manual ..
4/8/2024 12:29:27 AM • Building... • Answered on Apr 08, 2024
I have a Novoferm 553 garage door system. The remotes have stopped working.
Sounds to me like a cold solder joint on one of the boards
3/31/2024 1:13:56 PM • Building... • Answered on Mar 31, 2024
How many sand and stone and cement do you need or cubic meter of concrete
A concrete mixture ratio of 1 part cement, 3 parts sand, and 3 parts aggregate will produce a concrete mix of approximately 3000 psi. (20685 kpa)
3/25/2024 5:28:07 PM • Building... • Answered on Mar 25, 2024
My DTS 600 garage door open and close very slowly
Unlikely your garage door is battery operated. The remote and wall unit yes. The remote just tells the mains operated motor to get turning. The issue will either be that everything that moves needs lubricating, motor spindle, pulleys, chain, tracks and pivots, or the carbon brushes in the motor need replacing. https://www.google.com/search?q=DTS+600+garage+door and how to fix https://www.google.com/search?q=DTS+600+garage+door+opens+slowly ..
3/13/2024 5:23:31 PM • Building... • Answered on Mar 13, 2024
How do I fix an exterior mobile home door that's not lining up properly?
Question edited for clarity. Question moved from Cars and Trucks category. Look at the corners of the doors that hold the aluminium frame together and if it is a modular door, tighten them up. If it is a solid door, adjustment can be made by shimming behind the bottom hinge with a piece of cardboard. This will move the bottom out and up. ..
2/18/2024 9:28:00 PM • Building... • Answered on Feb 18, 2024
2answers
I have roller door opener merlin430R. I can not
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button. http://www.youtube.com/watch?v=7CqMy2UfG9k
2/15/2024 10:23:37 AM • Building... • Answered on Feb 15, 2024
Garage door opens too far and ends up 2 or 3 inches into the motor housing. How do I fix this issue.
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube. If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
1/15/2024 10:16:07 PM • Building... • Answered on Jan 15, 2024
tip
NHK Tiling
At NHK Tiling, our tiling process has been perfected over the years to give you the best results possible. Our Expert Tiling Service is perfected for a range of applications, styles and functions. Whether you require contrasting grout to make a statement with your kitchen splashback, or you need a Professional Tiler for tiling your swimming pool, NHK Tiling is the ideal choice for you. https://www.nhktiling.com.au/
on Dec 06, 2023 • Building Materials
tip
Granite Warehouse
GRANITE WAREHOUSE is a privately owned Western Australia business specializing in the wholesale of Granite, Marble, Limestone, Sandstone and our line of engineered stone, Stellastone, in slab form suited for the fabrication of kitchen and vanity benchtops as well as other building uses. Granite Warehouse was founded in 1995 by Tindaro (Tony) Tomeo to fill a need in the local Western Australian market for quality natural stone. With more than 40 years experience in the building industry, specializing in cabinet making and kitchen fit-out, Tony, with wife Susan and son Mark, built Granite Warehouse into the well-respected business it is today. With Tony and Susan's retirement, and in the best family tradition, Granite Warehouse has been taken over by Mark Tomeo who continues to develop the business to fill best the needs of those wanting to enjoy the beauty of stone installed to their home or business. https://granitewarehouse.com.au/
tip
Kwikcut & Coring
Having operated for the past 11 years in Western Australia, we offer a wide range of quality construction and demolition related services at competitive rates. Operating with the latest equipment endorsed by Traxx Construction Products, our fully qualified and professional operators work to the highest safety standards with excellent service guaranteed to meet your every need. Our team of qualified professionals, well trained and certified personnel who can operate the latest high-tech machines implement every project with care and 100% attention to details. To make sure that we are always ready for action and up-to-date with technologies, fast-paced world, procedures & regulations, we keep proving educational and on the job training to every professional we have in our team. Kwikcut believes in the importance of collaborating ideas and exploring innovative concepts not just for the benefit of our company but above all for the benefit of all our clients. We are customer focused, and we all share the same vision which is to put attention to details and produce nothing but excellent results for every project laid before us. We are highly professionals, trained, skilled, and licensed. For us, no job is too small or too big that we cannot undertake. https://www.kwikcut.net.au/
on Dec 05, 2023 • Building Materials
tip
Evolution Epoxy Flooring
Evolution Epoxy Flooring is Sydney's epoxy flooring expert, specialising in decorative garage coatings & concrete grinding. We only use advanced techniques, custom design, and Australian-made products to ensure the best concrete finish that suits the individual client's needs. https://evolutionepoxy.com.au/
/uploads/images/dp-undefined-undefined-0.png
on Dec 03, 2023 • Building Materials
My Liftmaster Wall Control (Large White Button) green light is not illuminated and I cannot open/close my garage. Remotes work fine. Which part needs replacement?
They have self diagnostic features and are 'smart'. Make sure there is nothing near the two door sensors and make sure they are clean. No model number given, but generic help in the link. https://www.google.com/search?q=Liftmaster+Wall+Control+Large+White+Button+green+light+is+not+illuminated ..
10/31/2023 11:39:56 PM • Building... • Answered on Oct 31, 2023
2answers
Why Kitchen Countertops are on Top and in Trend?
earth-friendly products is good for us this means it's products that was made from things that could be reuse and made better for our health and environment will be better
10/30/2023 11:40:38 AM • Building... • Answered on Oct 30, 2023
Genie KEP1 Universal Keyless Garage Entry System Logo
5 questions posted
Top Genie Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Genie Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Genie Building Materials
Most Popular Question
change key code in genie 35674r garage
