20 Most Recent
Hawking 2 USB + 1 Parallel Internet Print Server PS12U Print Server Questions & Answers
Need to print to: SYNERGIX COPY SYSTEM 8825
You need to access to the router control panel using a computer wired directly to the router.
After wiring a computer to router type the router IP address in internet explorer and enter ID/Passwd to open router control panel. You find router IP using IPconfig/All on CMD, or referring to router user manual.
On router firewall add the plotter IP as an exception.
On router advanced settings or firewall settings (depending on make and model) open port 994 that is closed.
On stations you may need to re-install the plotter as a new networked printer. If old router had been replaced or re set, then the workstations may not recognize the new plotter because of the different IP, and the plotter need reinstalling on each computer as a new networked device.
I would like to know how to set up HAWKING HWDN3 USB 2.0 Wireless 300N Dish Network Adapter for Windows 10?
Have you logged into your router from a computer? Is it designed for win10 or a previous version of windows? Sounds like its for a previous version id try rolling back the driver and or using compatibility mode for what ever version of windows it was designed for. Select the app, right click and there and or in properties is compatibility mode. Ps is it your router that you updated? You'll need to log into it with a computer and RJ45 network cable. The usual network cable. And do the initial configuration like setting bssid and password Wi-Fi ect.
3/17/2019 1:10:45 AM •
Hawking...
Answered
on Mar 17, 2019
Installing a hawking HOW2R1 Repeater and setup
The Setup Wizard will now prompt you to automaticallyconfigure your IP settings (recommended) and enter asecurity key if the network you are connecting to is anencrypted network. Enter the key and click Continue.If you do not know the security key of the network you are connecting to, consult your network administrator.
6/10/2014 10:53:23 PM •
Hawking...
Answered
on Jun 10, 2014
Don't have my istal disc
Clarification Question:What is the name and brand of the device that you want to have an installation disc?
3/14/2013 12:47:19 PM •
Hawking...
Answered
on Mar 14, 2013
