20 Most Recent
Engel 43 Qt.Portable Freezer. Questions & Answers
Water pooling in base of fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
3/4/2023 1:47:22 PM •
Engel 43...
Answered
on Mar 04, 2023
Noisy when compressor starts
MAY BE LOW ON FREON OR;
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
4/4/2015 8:39:38 PM •
Engel 43...
Answered
on Apr 04, 2015
At first i smelt a
it means your compressor hi pressure cause of blown fuse check the condenser fan if running ok if not replace capacitor or lubricate main shaft. then observe your comp. if working continues.
2/19/2011 3:54:33 AM •
Engel 43...
Answered
on Feb 19, 2011
My engel cools when set to max,but when it
this noise is normal due to starting period the compressor felt hard pumping operation but after a minutes it run smothly or maybe your unit has a year in using there is a possible wear and tear of mechanical parts a try to set it your thermostat on your desired setting then observe operation. the function of to sense the temp. inside and stop the comp. after reaching your desired temp.
2/6/2011 4:17:06 AM •
Engel 43...
Answered
on Feb 06, 2011
Our Engel runs continuously and freezes everything - it won't run as a normal fridge on any setting. Thank you
Take a tour to the world of Augmented Reality using three simple steps. Build your own AR with UniteAR App using any smart phone. We have solutions for Education, Marketing, Real Estate, Entertainment and Advertisements at lower costs. Our exclusive feature is you can upload 360° Video and also you can now upload contents like images, Videos, YouTube Videos, 3D Models, Animation, Audio/Podcasts and Websites. Download it now from Play Store / App Store. For more details, log onto
https://www.unitear.com
5/4/2019 4:19:02 AM •
Engel...
Answered
on May 04, 2019
