click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working ports (com&lpt) right click update driver click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive click start all programs accessories open windows explorer navigate to your data right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in or if you are downloading data from the internet once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb deviceif you need more help with this post a reply hope this helps you
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. click start click on my computer to open you should see your drive right click then select format another way click start control panel administration tools computer management disk management right right click on your usb drive select format if you need more help with this post a reply hope this helps
4 questions posted
20 Questions
15 Questions
2 Questions
