20 Most Recent
LG 32LK330 TV Questions & Answers
What are the microfarads of the capacitors on the main board?
This information should be on the side of the capacitors themselves. -Steve(EDIT)Now that we know that the capacitors seem to have been glued to the PCB with the required information concealed, great care MUST be taken so as not to damage the board. My next question would be to ask what reason would you have to suspect the capacitor(s) to be faulty? Is there physical damage to the case? I would STRONGLY recommend not using a heat gun to attempt removal of any component from a printed circuit board. The heat these generate is easily enough to lift the copper runs putting you into an entirely new world of hurt. I would suggest desoldering first with a low-power iron (less than 15W) THEN a fine X-acto type blade to work the component free.
My lg tv has power and blue light comes when powered up the goes to red blinking light never a picture or audio
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
