20 Most Recent
Samsung HLN5065W 50" DLP TV Questions & Answers
No color
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence,,,http://factory-reset.com/wiki/Samsung_Service_Menu
Where can I get a samsung dlp chip for a HLN5065W
Google but in my view a big waste of time and money, seen about a dozen here who tried and were then with a set with new problems and crying about it. If the Light engine is too expensive buy a new set.
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
3 blinking lights
If lamp did not cure it:Look with lamp removed in direction lamp faces---look to see if the color wheel is shattered or missing pieces--common failure.Usually but not always if Wheel is bad you heard before a high pitched or fan like sound when set was on.The only other common failure is the Ballast which powers and drives the lamp----At the moment of turn on if the lamp lights briefly and goes out the Ballast is less likely to be bad.
Samsung dlp dnie
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
