20 Most Recent
Henry Numatic "" Canister Vacuum Questions & Answers
Cant open to empty
The two clips on the side got to be pull right out try a little oil WD40 work in with a paintbrush and use the handle to leaver them out
Top falls off when carried
There are two clips on the side make sure there pull right out and the filter is push right down fit the top on and bang the side clips back in some are hard to clip back in I have to bang mine back in x
Why is my henry vacuum cleaner not working motor running but no suction ?
Hi I will try to guide you though this problem.
When you switch it on do you get air blown out of the vent on the machine housing.if not there may be a blockage.
if you take the hose off, do you have suction on the main body.
if so pipe is blocked.
if no suction then, do you have a bag in it. If so remove the bag and reassemble and try again.
there should also be a sealing ring with a fabric on it between the motor head and the body, is this very dirty or missing.
if none of the above works then I would assume that the fan is adrift on the motor.
i would advise a qualified person investigates further as risk of electric shock if you dismantle the advice.
please let me know how you get on.
