20 Most Recent
Google Translate Questions & Answers
How To boost Battery Power In Android
Are you suffering from the rapid battery drainage on your Android? If so, try the Greenify app in the Google Play store. It hibernates the app that are running in the background and saves more battery power than before. I hope my tip will be useful Android users
. It can hibernate the app that
How to Play Music and Record Video on an Android Phone
As an Android user myself, I know how irritating it is when you are recording a video and try to play a song, but it stops recording. Thankfully, I found an app that works in the background:
Background Video Recorder Apps on Google Play . However, you have to follow the following steps to play a song at the same time as recording:
Step One: Install Background Video Recorder
Step Two: Open your music app (Google Play Music, Youtube Red, Spotify, etc.)
Step Three: Start playing the song
Step Four: WITHOUT pausing the music, open Background Video Recorder app and begin recording.
When you are done recording, hit STOP in the Background Video Recorder app and enjoy your video
[DISCLAIMER] This tip is not an advertisement. I make no money from Background Video Recorder app for posting this and I endorse the product purely for the betterment of other Fixya users.
How to Fix The Dead Android and Red Triangle
I think it,s time for a factory reset , you will lost all you data !!!!!
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
android man on his back with red triangle on his chest Google Search
How To Skip Android Google Play Signup When Playing Games
Hi, friends how are you... in this tip, you going learn about that how to skip google play games signup when playing android games. did you feel that when you open android games there you can see a pop-up window saying that signup for the google play game to play this app looks irritating right? don't worry dude there is the very simple solution for this problem.
If you see that window in future just touches somewhere on the screen tada.... the signup window will be gone....
My htc one x is very slow
Hi,(H) means HSDPA, which means faster internet connection.It is also called as 3G.If you turn off your internet connection, you can't see (H).Cheers...!!!
Will not play videos on my phone
Depends on the phone specifications, CPU generaterion (6,7, neon,...) and of course application.Try using Rockplayer, Moboplayer or MX player which feature software video decoding and should play without any problems.
How to i add a google to my pandigital? It keeps
You are trying to add new account?Try using full address with gmail.com, if still unsuccesful, try using googlemail.com.If still doesn't work try to login from PC (or phone browser to check if the account can be accessed- maybe 2 step google verification active?)
LG AXIS CAMERA APP NOT RESPONDING..WHAT COULD BE
Hello Woody,
Try using app after each step.
First thing to try is somewhat obvious but restart your phone, will solve a majority of the little issues that pop up.
Go into settings/applications/manage applications, then click the all tab. If the camera app you are having issues came with the phone it will be named "camera", click clear data
Navigate to the same screen in settings and uninstall the application(Cannot uninstall the app that was preinstalled)
Use google market to install any high rated camera application.
Factory reset, this will wipe all of the information off of the phone, and return the software to the condition it was in the day you purchased it. Settings/SD card & phone storage/Factory data reset/Reset phone.
If none of these steps have fixed your issue contact your service provider, and they will be able to help you get a replacement. With any luck free of charge.
Good luck, hope this was helpful
My Google account has been
Best practice would be to contact google support, they will respond in 48 hours and will be able to give you information why was it disabled.
Get the old version of words with friends by zynga??
First, make the Google play store not auto-update apps. Go to the play store, go to settings, then set auto-update apps to never. Then, you have to make your phone be able to install non-google play store apps. Go to your phone's settings, tap on security, and check the box that says "allow installation of non-market apps." After that, look up old words with friends apk on your web browser. Download the old words with friends apk file, open it, and install it. You will have the old words with friends app.
1/25/2024 6:09:32 AM •
Android Apps
Answered
on Jan 25, 2024
