20 Most Recent
Toshiba Satellite R15-S822 Tablet PC Questions & Answers
No Sound..Missing Multimedia Audio Controller
Go to the toshiba, and download the audio drivers for your laptop.
In the device manager, right click and uninstall the device.
Reboot
Reinstall the audio drivers.
Do it by the downloaded file, rather then the Windows Wizard.
If the downloaded file does not have a setup.exe or an install.exe, go to the device manager, and choose "Update drivers". Point it at the folder you downloaded the drivers to, and let it do the install.
If there is a problem after that, please post any error messages.
1/17/2012 3:57:59 AM •
Toshiba...
Answered
on Jan 17, 2012
My toshiba r15-s822 says it
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
8/23/2011 4:41:35 PM •
Toshiba...
Answered
on Aug 23, 2011
My Toshiba r15-s822 isn't connecting
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
8/18/2011 2:12:11 AM •
Toshiba...
Answered
on Aug 18, 2011
I have a Toshiba R15 S822, my problem is that my
I might not be necessary to reset to factory settings. Just go to the Toshiba.us support site and download the drivers for the Tablet PC (that includes the WAcom driver, all the tablet PC extensions).
If you have the Recovery CD, you can run it from inside Windows XP and reinstall selectively all you need.
Just to set things straight, the screen of the R15 reacts to the Wacom pen only, not to your finger or some other plastic tipped pen.
8/18/2011 12:05:26 AM •
Toshiba...
Answered
on Aug 18, 2011
The power button doesnt start the laptop
Toshiba Satellite R15-S822 Tablet: Battery is charged and operational power supply (charging light is on) is plugged into power port on back side of laptop: Problem is sliding "power on" switch does not start laptop - no sign of any electrical activity...
7/20/2011 3:06:20 PM •
Toshiba...
Answered
on Jul 20, 2011
I need a driver for
Here is a link to the Toshiba support web site for the
Satellite R15-S822. Specify the operating system to refine the search or look for the driver in the list.
If you have the recovery CD you can also use it.
5/29/2011 10:22:40 AM •
Toshiba...
Answered
on May 29, 2011
Want to reinstall windows XP
hit dell, f2 or any other function keys contineously till you see boot menu..then change boot preference to cd/dvd
5/4/2011 1:06:35 AM •
Toshiba...
Answered
on May 04, 2011
After formating using window xp,cant
You need to install all the necessary drivers to your Tablet PC, including the Sound Card Driver & Video Card Driver to be able to use properly your Tablet PC. Use the installation disk that came with the product when you've purchased it.
4/5/2011 11:51:58 AM •
Toshiba...
Answered
on Apr 05, 2011
