Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problemIt could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area If this does not fix the problem you might try you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you if your computer came with a motherboard disk the drivers could be on it or you will need to download one http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
if this driver package is not right http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)don
35 questions posted
119 Questions
27 Questions
15 Questions
14 Questions
