20 Most Recent
Bunn 340000068 6 Gal Model Black ULTRA2 AFI Frozen Drink Machine Questions & Answers
Left auger not working.
there is a sensor on each side in the back that monitor the speed of the auger to determine thickness of the slush. if the sensor is dusty, it causes an error.
remove the 2 screws and the panel in the back behind the bowl on that side. you will see the motor and the sensor in front of it. use compressed air to blow out any dust. next, check to see if there are 2 pins on the shaft that pass the sensor. if one is gone, you will need to have it replaced.
BUNN COLD DISPENSER HAVE FAULT
Hi mikelupe64,
I saw your post you mentioned that the left barrel has a fault, and it Drops OFF voltage when the compress starts.
Part#'sAssembly ManualPossible that the Left condenser is experiencing problems causing the left barrel to drop voltage when compress starts.
On a bunn ultra 2 dispenser i have a fault on the
It can be weak compressor or faulty auger motor or faulty valve connections.As you mentioned that valves loose voltage as compressor comes on, this is indication of weak compressor or main board.If the compressor voltage checks ok then its main control board problem.--------
You will have to test it with meter.
This unit has a warranty on it, if its not very old.---------
The warranty details is as follows:--
1) All equipment other than as specified below: 2 years parts and 1 year labor.
2) Electronic circuit and/or control boards: parts and labor for 3 years.
3) Compressors on refrigeration equipment: 5 years parts and 1 year labor.
4) Grinding burrs on coffee grinding equipment to grind coffee to meet original factory screen sieve analysis:
parts and labor for 3 years or 30,000 pounds of coffee, whichever comes first
This should help.Thanks.Helpmech.
I have a bunn ultra 2 slush machine.everything comes on its just the compressor kicks on and right off afterwards not allowing product to freeze.what could be the problem.thanks in advance
If your Bunn Ultra 2 slush machine's compressor is turning on and off immediately, not allowing the product to freeze, there could be a few possible causes. Here are a few things you can check:
- Check the thermostat: Make sure that the thermostat is set to the correct temperature and that it is functioning properly. A faulty thermostat can prevent the compressor from turning on.
- Check the compressor relay: The compressor relay is responsible for turning the compressor on and off. If the relay is faulty, the compressor may not stay running. You can check the relay by using a multimeter to test for continuity across the relay's terminals.
- Check the compressor motor: The compressor motor could be faulty and not able to start or stay running. You can check the motor by using a multimeter to test the winding resistance.
- Check the condenser coils: The condenser coils could be dirty or clogged with dust, which can cause the compressor to overheat and shut off. Clean the condenser coils with a brush or compressed air to remove any dust or debris.
- Check the compressor's oil level: If the oil level is low, the compressor could be damaged.
- Check the overload protector: The overload protector is a safety device that is designed to protect the compressor from damage caused by excessive current. If the overload protector has tripped, the compressor will not start or stay running.
It's worth noting that a compressor not staying running could also be caused by a more complex issue
Bunn gourmet ultra 2 message bad tic clock
The Bunn Ultra-2 originally came with several circuit boards, including the main control board and a small memory board also known as the "TIC Clock". This little board, screwed in directly behind the main control board and has a small round metal circuit on it that looks like a watch battery, but it is not -- the metal "Can" contains the timing and memory functions for the main control board.There is also a small battery inside the "can", which maintains the memory when power is removed from the machine. Over time, this battery will fail and you will see an error message on your LCD readout that says ":Bad TIC Clock". In the past you could just buy a new TIC Board from Bunn and install it and you'd be back on your way again. But, Bunn no longer sells the TIC Board and instead Bunn wants you to purchase a new Main Circuit Board that has the memory and timing functions built right on the new Main Board. The list price is over $200.You can now purchase a TIC Board Rehabilitation kit from the Margarita Guys for under $50 which will replace the failed circuitry on the small TIC Board. Go to ebay and search "Bunn TIC Board" and you will see the kit available there. It includes all the necessary tools, 9 pages of detailed instructions and annotated photos, free Priority Shipping, and free phone access to their Bunn trained and certified Journeyman Technicians for any help you may need. This should be the perfect answer to resolve your Bad TIC Clock message and the working errors that come with it.
