20 Most Recent
Panasonic TXL42S10B 42 HDTVReady LCD TV Questions & Answers
Srevice mode
Replacement of ICs:
When Pro4 IC (IC8000) is replaced, NAND FLASH (IC8900) should be also replaced with new one the same time. When NAND FLASH (IC8900) is replaced, Pro4 IC (IC8000) is not necessary to be replaced the same time. After the replacement of IC, SELF CHECK should be done to generate the final KEY data. How to SELF CHECK: While pressing [VOLUME ( - )] button on the main unit, press the MENU button on the remote control for more than 3 seconds. TV will be forced to the factory shipment setting after this SELF CHECK.
USB HDD Recording:
General information:
Digital TV programmes can be recorded in USB HDD.
A One-to-One key generated in A-board by SELF CHECK binds TV and USB-HDD for communication. That key is only one key for them. If the key is difference, TV can not access USB-HDD.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
14 red blinks wont stay on, I'd love to find the service manual to understand what 14 blinks means
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
7/8/2015 7:59:24 AM •
Panasonic...
Answered
on Jul 08, 2015
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions.
How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM •
Panasonic...
Answered
on Feb 17, 2024
On the Panasonic DMR-EZ47V, it had a VCR tape stuck in it, when turn on shows, F60, now doesn't show anything.
Yes bad caps on the video processing board according to the links
iFixit
https://www.ifixit.com > Answers > View > F60+error...
Oct 8, 2014 - Ron, F60 is a general error code usually related to a
failure on the video processing board. You could fix this by just replacing that board ...
I have a DMR EZ485 that shows an error code of F60. What
JustAnswer
https://www.justanswer.com > Electronics Question
Jan 5, 2018 - The
F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Panasonic DMR-ES40V Drive and F60 Code
AVS Forum
https://www.avsforum.com > threads > panasonic-dmr...
Oct 26, 2014 -
F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked. But first try a "cold ...
Another Capacitor Failure, Another Fix
EE Times
https://www.eetimes.com > another-capacitor-failure-a...
Jan 21, 2019 - An online search revealed that
F60 was a general failure code, usually caused by a failed aluminum electrolytic capacitor. Time to get the ...
Picked up a Panasonic DMR-EZ475V that throws a code ...
Reddit · r/VHS
2 comments · 2 years ago
The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
My Panasonic DMR-ES40V DVD/VHS player now says " ...
JustAnswer
https://www.justanswer.com > recorders-and-players
Dec 23, 2012 -
F60 is a general error code indicating a failure on the video processing board. First try a "cold boot". Unplug the recorder again, allow it to ...
1/30/2024 3:40:50 AM •
Panasonic...
Answered
on Jan 30, 2024
Need to access menu on Panasonic viera without remote
If you need to access your Panasonic television's menu and you don't have a remote, then your best option is to use the physical buttons on the television itself. There is a MENU button, often on the back of your Television.
12/11/2023 9:37:19 AM •
Panasonic...
Answered
on Dec 11, 2023
