20 Most Recent
Toshiba Satellite P35-S605 Notebook Questions & Answers
Toshiba Satellite Pro P35-S605 beeps upon power up then crashes and reboots.
Can you get into Safe Mode? I suspect your configuration needs tweeking. Also I would immediately go into the Bios and make the boot order be CD, HD.. etc. Also make note of any hidden partitions such as H, or K. Those sometimes house a mirror of the factory version of XP... like when it was new. Good luck
11/21/2012 3:19:05 AM •
Toshiba...
Answered
on Nov 21, 2012
My laptop keeps shutting donw
Clogged heatsink and fan / copper radiator. You need to remove the CPU cover (if possible) and hoover around the fan area to remove dust and debris. You mat have to take it apart to get to the cooling parts though. IF you chosoe to remove the heatsink to clean thoroughly, remember to apply some CPU grease between the cpu and heatsink.
1/12/2011 10:22:13 PM •
Toshiba...
Answered
on Jan 12, 2011
Hi since I installed windows 7 in my toshiba
You need to configure it as a second display. Connect the tv to the laptop, right-click on the desktop and choose Screen resolution, select the 2, put a resolution supported by your tv and select the Extend option.
7/1/2010 2:33:04 PM •
Toshiba...
Answered
on Jul 01, 2010
Cant open mirosoft website
When you open your browser and it cannot load the web page that means there is no internet connection... if there is... then the connection is not stable..
Try this, could help you stabilize your connection...On the top of your web browser, on the File menu , uncheck the "Work Offline"...........If you are using a wireless internet connection.. disable the firewall setting of your windows so that windows will allow the connection of internet and will not be strict...If you are using a broadband router make sure it is receiving high signal... and make sure to keep away the unit 1 meter from any live wiring or wall outlet..
I hope that solve your connection issues..
Much appreciated if you rate this help..thanks..
5/24/2010 8:02:39 PM •
Toshiba...
Answered
on May 24, 2010
I recently reformated the computer with the
it sounds like it is. go into the divice manager and see if it is showing up here, if it is uninstall it and reboot the computer, when the computer turns back on it should see the wireless card and try and reinstall it. if this dosen't work download the driver from the toshiba web site, use a cat5 cable to get the internet from the modem. hope this helps
3/17/2010 10:33:12 AM •
Toshiba...
Answered
on Mar 17, 2010
MY COMPUTER IS WIPED OUT,
Please go into the BIOS and set the BIOS to BOOT from the DVD FIRST, you cannot use that DVD until you set the boot order. If this still will not work, you may have to get a Windows install DVD and try a repair install, if that fails then you will have to do a complete reinstall of the Operating System.
BTW try pressing F8 at boot up and see if it will BOOT into Safe Mode, if it does, do a system restore. I suspect however that you will have to do a complete reinstall. It is also possible that the hard Drive has gone Bad this may have to be replaced, and THEN the operating system installed again. Also before you do this from another PC download all the drivers from the manufacturers web site, for your exact model & operating system. and put them on a memory stick, this way you can install all the drivers again at system install.
3/16/2010 10:05:05 AM •
Toshiba...
Answered
on Mar 16, 2010
What do you do regarding the toshiba satellite
Depending on a few things, this may be a feature or a problem.
Does it seem to shut down within a specific time period?
Does this time period remain constant, and change only if on battery vs. plugged in?
If this is the case then it probably your power management settings.
Check the control panel, and configure them to your preference.
To access the Power Options in the Control Panel in XP:
Start > Control Panel > Power Options
There you will see specific settings regarding monitor, hard disks and standby. Your machine is most likely going into standby, check the time, and select something more appropriate for your needs or disable it all together.
In Vista, you will see a more streamlined set of options. "Always
On/Plugged In" "Minimal Power Saving" Etc. would be the best choice
The choice is yours.
Let us know.
Good luck
4/16/2009 8:42:33 PM •
Toshiba...
Answered
on Apr 16, 2009
Continual reboot with second memory module
Your memory isn't an exexact match. The 512MB you have in is probablyis Kingston, part # KT3311/512, PC2100/2700, 512MB DDR. You should get Kingston part # KT3311/1G, PC2100/PC2700, 1 GB DDR. You can use another manufacturer but everything must match exactly execpt the size of course. The speed, DDR, everything. Make sure you have the new chip seated correctly and in all the way first. Of course if it doesn't match the specs of your other chip it won't matter. Best thing to do if buying locally is take the first chip with you. If not buying locally, have it with you when you order to make sure it matches.
3/29/2008 3:57:26 AM •
Toshiba...
Answered
on Mar 29, 2008
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
