20 Most Recent Toshiba Satellite A65-S126 Notebook Questions & Answers
How can i reset the bios password cause lost it
remove cmos battery. search it. theres a backdoor for toshiba
1/13/2015 2:59:45 AM • Toshiba... • Answered on Jan 13, 2015
2answers
Need password unlock code for toshiba laptop model A65-S126
i forgot my password to sign in
10/15/2013 6:25:06 AM • Toshiba... • Answered on Oct 15, 2013
How to fix error f3 f200 002 satellite c850 IS it
replacing a hard drive is a lot cheaper then a computer I know this because I work on computers for a living. By the way if you have not done a backup of your data and the hard drive you have now is completely dead as it won't run then you have lost your data. when you by a new hard drive they don't have Windows or any information to make your computer run, so you will need a windows Operating system disc to reinstall Windows on the new hard drive.
10/3/2013 3:00:45 PM • Toshiba... • Answered on Oct 03, 2013
Toshiba Satellite A65-S126 keyboard no longer works
If you have the disk or driver for keyboard then reload it.If not then use the mouse and click on the Start button, use the mouse's right button on Computer (My Computer). Select Manage. When the Computer Management console appears, Select Device Manager. Expand the Keyboard Section. Right Click on your computer name and select Scan for hardware changes.If this fails to reload the driver then right click on the keyboard item that says Unknown and select Update Driver Software.
1/29/2013 7:25:01 AM • Toshiba... • Answered on Jan 29, 2013
2answers
Can't find Ethernet controller driver for a
Hi deyanite...
Go to the following website and download your FREE ethernet driver.
Please take time to rate me
http://www.driversforfree.com/omn_ofm_omd_drd/toshiba/satellite/a65-s126/toshiba-realtek-ethernet-lan-driver/search.aspx
12/1/2012 4:32:03 PM • Toshiba... • Answered on Dec 01, 2012
0answers
Where is the master reset button
There is no master reset button for a laptop. You can use your recovery feature (if available) or use the disk that came with the laptop to reinstall the software. Either option will give you a fresh start.
7/7/2012 2:39:12 PM • Toshiba... • Answered on Jul 07, 2012
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.1-THE CHARGER2-THE BATIF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
4/27/2012 3:23:01 PM • Toshiba... • Answered on Apr 27, 2012
Toshiba 320gb can't install
If this is a newer type hard drive the layout configurations are going to be completely different and will not work in the older laptops. Go to www.ebay.com and type: your make and model and refine search to hard drive.
3/28/2012 5:49:50 PM • Toshiba... • Answered on Mar 28, 2012
My toshiba laptop model number Satellite A65-S126 will not come on. the two green lites in front are on that shows the battery and power is on but it will not power up, what do i do?
If the hard disk drive is running , that means the laptop is on and the lcd has been damaged. get your lcd replaced to fix the problem. if that is not the cause, try reformatting.
3/2/2012 3:30:44 AM • Toshiba... • Answered on Mar 02, 2012
Not hearing any sound when playing audio cd
A lot of factors needs to be considered. First, make sure the audio is not on mute. Second, make sure the audio device driver is up to date. Third, the audio device might be defective.
9/22/2011 9:56:53 PM • Toshiba... • Answered on Sep 22, 2011
2answers
How much GB does the
Here is the specifications of the Toshiba Satellite A65-S126
  • Built-in Devices Wireless LAN antenna , Stereo speakers
  • Width 13.5 in
  • Depth 11.1 in
  • Height 2.1 in
  • Weight 7.7 lbs
  • Localization United States
  • Notebook type Desktop replacement (7.5 + lbs.)
  • Wireless capabilities IEEE 802.11g , IEEE 802.11b
  • Processor
  • Processor Intel Celeron 2.8 GHz
  • Data Bus Speed 400.0 MHz
  • Chipset Type ATI Mobility Radeon 7000 IGP
  • Cache Memory
  • Type L2 cache
  • Installed Size 128.0 KB
  • RAM
  • Installed Size 256.0 MB / 1.25 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor SO DIMM 200-pin
  • Configuration Features Provided memory is soldered
  • Storage Controller
  • Storage controller type IDE
  • Storage
  • Floppy Drive None
  • Hard Drive 60.0 GB - 4200.0 rpm
  • Hard drive type Portable
  • Optical Storage (2nd)
  • 2nd optical storage type None
  • Optical Storage
  • Type CD-RW / DVD-ROM combo
  • Read Speed 24x (CD) / 8x (DVD)
  • Write Speed 16x
  • Rewrite Speed 4x
  • Display
  • Display Type 15.0 in TFT active matrix
  • Max Resolution 1024 x 768 ( XGA )
  • Widescreen Display No
  • Color Support 24-bit (16.7 million colors)
  • Video
  • Graphics Processor / Vendor ATI Mobility Radeon 7000 IGP Shared video memory (UMA)
  • Audio
  • Audio Output Sound card
  • Audio Codec Realtek ALC250
  • Compliant Standards DirectMusic , DirectSound , DirectSound3D
  • Audio Input None
  • Input Device(s)
  • Input device type Keyboard , Touchpad
  • Telecom
  • Modem Fax / modem
  • Max Transfer Rate 56.0 Kbps
  • Protocols & Specifications ITU V.92
  • Networking
  • Networking Network adapter
  • Wireless LAN Supported Yes
  • Data Link Protocol Ethernet , Fast Ethernet , IEEE 802.11g , IEEE 802.11b
  • Compliant Standards IEEE 802.11b , IEEE 802.11g
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 (total) / 1.0 (free) x PC Card - SO DIMM 200-pin , 1.0 (total) / 1.0 (free) x Memory - Type II
  • Interfaces 1.0 x Headphones - Ethernet 10Base-T/100Base-TX - 25 pin D-Sub (DB-25) , 1.0 x Microphone - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 1.0 x Parallel - Output - RJ-11 , 1.0 x Network - Phone line - Mini-phone 3.5 mm , 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm , 1.0 x Modem - Input - RJ-45 , 1.0 x Display / video - VGA - 4 pin USB Type A , 3.0 x Hi-Speed USB
  • Miscellaneous
  • Features Power-on password , Hard drive password , Security lock slot (cable lock sold separately)
  • Compliant Standards ACPI , Plug and Play
  • Power
  • Power Device External
  • Voltage Required AC 120/230 V ( 50/60 Hz )
  • Power Provided 90.0 Watt
  • Battery
  • Technology Lithium ion
  • Installed Qty 1.0 / 2.0 (max)
  • Capacity 4300.0 mAh
  • Operating System / Software
  • OS Provided Microsoft Windows XP Home Edition
  • Software AOL , Drivers & Utilities , ArcSoft ShowBiz DVD , Norton Antivirus 2004 (3 months subscription) , Toshiba Custom Utilities , Microsoft Office OneNote 2003 , Microsoft Works , AT&T WorldNet Service , Toshiba Touch and Launch , InterVideo WinDVD 4 , Toshiba Notebook Maximizer , Toshiba Speech System , Toshiba ConfigFree , Adobe Acrobat Reader
9/13/2011 5:12:56 PM • Toshiba... • Answered on Sep 13, 2011
Hello , I recently cleared
Improve the Fixya.com experience for everyone by voting!
Unfortunately, I would either have to be in the chat mode or on the telephone with you to fully analyze your problem and provide a coherent answer. But don't despair because there is a little FREE program that may solve your problem.
It happens periodically that our computer shuts down, restarts, hibernates or some other weird thing when we really don't want it to. I'm going to pass on to you a FREE and hard to believe program from Microsoft! I have no idea why this little program hasn't been advertised but then I don't own their stock.
Just click on the following link and your problem should be solved: Download Microsoft's Fixit
I don't know your skill level so my suggestion is that you utilize the automatic function of Fixit.
Be a hero and fix your friends' computers; just don't tell them how you did it! That will be our little secret.
All the best,
Ben
7/21/2011 10:39:11 PM • Toshiba... • Answered on Jul 21, 2011
Can I upgrade the video
No, you can't upgrade graphics hardware on a laptop. It's integrated on the motherboard. There isn't room in a laptop case for expansion slots like you have in desktop, so you can't change what's there. All you can do in a laptop computer is make sure you have the most up-to-date graphics drivers, which can be downloaded from the manufacturer's support site.
6/30/2011 3:28:38 AM • Toshiba... • Answered on Jun 30, 2011
I'm trying to locate the internal battery.
You can find a good step by step for finding the battery at the following site:
http://www.irisvista.com/tech/laptops/ToshibaA65/satA65_1.htm
You should be able to take the bottom cover off after Step 3, which should expose the CMOS(internal) battery. If you can't see it after Step 3, you will have to keep following the steps until the battery is exposed.
Use something thin and sharp to pop the battery out of its socket, and be sure not to drop it on your motherboard.
6/2/2011 2:54:05 AM • Toshiba... • Answered on Jun 02, 2011
Toshiba Satellite A65-S126 Notebook Logo
115 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
39 t find ethernet controller driver
  • Computers & Internet
