20 Most Recent Lowrance LCX-15MT GPS Receiver Questions & Answers
0answers
I have a LCX-15MT Depthfinder
This is a link to the owners manual. Should have info you need. https://www.lowrance.com/Root/Lowrance-Documents/LCX-15MT_0133-49.pdf
6/23/2017 1:31:03 AM • Lowrance... • Answered on Jun 23, 2017
My Lowrance LCX-15MT GPS unit did power up, but
batteries go flat with use if it has a battery it will be replaceable it is rechargeable it will have a plug jack for a charger download the pdf user manual from the manufacturer site
4/19/2017 12:02:21 AM • Lowrance... • Answered on Apr 19, 2017
I need LCX-15MT 2.1.0 update to 3.6.0?
Software Updates Check this link to get the software. Gopakumar Gopalan Google
6/18/2014 5:31:14 AM • Lowrance... • Answered on Jun 18, 2014
2answers
I get a message on the screen of my LCX-15MT
To get the updates, start with a blank card. The first time you use it you will plug it into the card reader. It may ask you to format here. If so click "OK". If not: Go to "My Computer" - it will show up there as a storage device. Right click and select format. It will in effect "erase" the card and "prep" it for further use.
Follow the prompts. When done you should be able to go to the site you wish to download from and when you click on the file it will ask if you want to save it. "Yes" to your "Desktop". Once done you can open "my computer" - double click on the card reader. It will open with nothing in it. Reduce the screen pic for the reader so you can also see your desktop. Put cursor on desktop file - Right click and hold the button down while you drag the file to the card reader file and let go of the button. Click "Copy Here". Now you should be able to take the card and insert it into the display to run the actual update.
7/27/2013 7:51:38 PM • Lowrance... • Answered on Jul 27, 2013
0answers
Does it have achart plotter
Out of the box, no. To get GPS/Mapping/chartplotting features, you have to hook up a separate LGC-12S 12-parallel channel GPS receiver/antenna device which is sold separately.
3/11/2011 12:42:30 PM • Lowrance... • Answered on Mar 11, 2011
When I switch on my
Here is a link that you may find helpful, it contains this model's user manual via PDF
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
3/3/2011 3:12:37 AM • Lowrance... • Answered on Mar 03, 2011
I have a LCX-15MT depth
Matt,
Was the device subjected to a thud or a ****? It seems that the LCD has got disconnected from the main board of the device. It is getting the power but no data.
Please open it up and reconnect the data cable. It should be press fitted. And if you do not have the necessary tools to open it then please visit the service center for the necessary.
2/27/2011 10:53:33 PM • Lowrance... • Answered on Feb 27, 2011
2answers
Unit lights up and tries to power on but stays in
Your GPS stores its data on a memory card. that is waypoints, routes, and tracks, as well as GPS, GIS, and CAD data. Have you got any backup? otherwise, electrical noise from the motor, or an accessory maybe interfering with unit. changing wiring cables routes may help. check the transducer cable for breaks, cuts, or oinched wires.
Regards
5/22/2010 10:08:06 PM • Lowrance... • Answered on May 22, 2010
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
2. Press and hold the ZIN&ZOUT Keys at the same time
PLEASE DON'T FORGET TO RATE !
4/16/2010 10:57:01 PM • Lowrance... • Answered on Apr 16, 2010
Getting an accurate gps reading but not giving
hello sorry to hear your issue .. I do have some suggestions for you to try.
__________________________________________________________
There are many factors which can influence your Sonar to not function properly.
It could be your sonar sensitivity settings, or your sonar calibration. Because there is so much depth relating to the sonar category I have taken the time to pull up your manual.
LCX-15mt Gps receiver
review pages 12-24 on: sonar setup, calibration sensitivity, and other features.
also in the back of the manual you will find sonar troubleshooting. I have also pasted it here for easy access.
Unit freezes, locks up, or operates erratically:
1. Electrical noise from the boat’s motor, trolling motor, or an accessory
may be interfering with the sonar unit. Rerouting the power and transducer cables away from other electrical wiring on the boat may help. Route the sonar unit’s power cable directly to the battery instead of through a fuse block or ignition switch
2. Inspect the transducer cable for breaks, cuts, or pinched wires.
3. Check both the transducer and power connectors. Make certain both
are securely plugged in to the unit.
Weak bottom echo, digital readings erratic, or no fish signals:
1. Make certain transducer is pointing straight down. Clean the face of thetransducer. Oil, dirt, and fuel can cause a film to form on the transducer,reducing its effectiveness. If the transducer is mounted inside
the hull, be sure it is shooting through only one layer of fiberglass and
that it is securely bonded to the hull. Do NOT use RTV silicone rubber
adhesive or Marinetex
2. Electrical noise from the boat’s motor can interfere with the sonar. Thiscauses the sonar to automatically increase its Discrimination or noise rejection feature. This can cause the unit to eliminate weaker signals such as fish or even structure from the display.
60
3. The water may be deeper than the sonar’s ability to find the bottom. If
the sonar can’t find the bottom signal while it’s in the automatic mode,
the digital will flash continuously. It may change the range to limits far
greater than the water you are in. If this happens, place the unit in the
manual mode, then change the range to a realistic one, (for example,
0-100 feet) and increase the sensitivity. As you move into shallower
water, a bottom signal should appear.
4. Check the battery voltage. If the voltage drops, the unit’s transmitter
power also drops, reducing its ability to find the bottom or targets.
Bottom echo disappears at high speeds or erratic digital reading or
weak bottom echo while boat is moving
1. The transducer may be in turbulent water. It must be mounted in a
smooth flow of water in order for the sonar to work at all boat speeds.
Air bubbles in the water disrupt the sonar signals, interfering with its
ability to find the bottom or other targets. The technical term for this is
Cavitation.
2. Electrical noise from the boat’s motor can interfere with the sonar. This causes the sonar to automatically increase its Discrimination or noise rejection feature. This can cause the unit to eliminate weaker signals such as fish or even structure from the display. Try using resistor spark plugs or routing the sonar unit’s power and transducer cables away from other electrical wiring on the boat.
No fish arches when the Fish ID feature is off:
1. Make certain transducer is pointing straight down. This is the most
common problem if a partial arch is displayed.
2. The sensitivity may not be high enough. In order for the unit to display a fish arch, it has to be able to receive the fish’s echo from the time it
enters the cone until it leaves. If the sensitivity is not high enough, the
unit shows the fish only when it is in the center of the cone.
3. Use the Zoom feature. It is much easier to display fish arches when
zoomed in on a small range of water than a large one. For example,
you will have much better luck seeing fish arches with a 30 to 60 foot
range than a 0 to 60 foot range. This enlarges the targets, allowing the
display to show much more detail.
4. The boat must be moving at a slow trolling speed to see fish arches. If
the boat is motionless, fish stay in the cone, showing on the screen as
straight horizontal lines.
61
NOISE
A major cause of sonar problems is electrical noise. This usually appears on the sonar’s display as random patterns of dots or lines. In severe cases,it can completely cover the screen with black dots, or cause the unit operate erratically, or not at all.
To eliminate or minimize the effects of electrical noise, first try to determine the cause. With the boat at rest in the water, the first thing you should do is turn all electrical equipment on the boat off. Make certain the engine is off, also. Turn the sonar unit on, then turn off ASP (Advanced Signal Processing). There should be a steady bottom signal on the display. Now turn on each piece of electrical equipment on the boat and view the effect on the sonar’s display. For example, turn on the bilge pump and view the sonar display for noise. If no noise is present, turn the pump off, then turn on the VHF radio and transmit. Keep doing this until all electrical equipment has been turned on, their effect on the sonar display noted, then turned off.
If you find noise interference from an electrical instrument, trolling motor,
pump, or radio, try to isolate the problem. You can usually reroute the
sonar unit’s power cable and transducer cable away from the wiring that
is causing the interference. VHF radio antenna cables radiate noise when transmitting, so be certain to keep the sonar’s wires away from it. You may need to route the sonar unit’s power cable directly to the battery to isolate it from other wiring on the boat.
If no noise displays on the sonar unit from electrical equipment, then make certain everything except the sonar unit is turned off, then start the engine. Increase the RPM with the gearshift in neutral. If noise appears on the display, the problem could be one of three things; spark plugs, alternator, or tachometer wiring. Try using resistor spark plugs, alternator filters,
or routing the sonar unit’s power cable away from engine wiring.
Again, routing the power cable directly to the battery helps eliminate noise problems. Make certain to use the in-line fuse supplied with the unit when wiring the power cable to the battery.
When no noise appears on the sonar unit after all of the above tests, then the noise source is probably cavitation. Many novices or persons with limited experience make hasty sonar installations which function perfectly in shallow water, or when the boat is at rest. In nearly all cases, the cause
of the malfunction will be the location and/or angle of the transducer. The
face of the transducer must be placed in a location that has a smooth flowof water at all boat speeds. Read the transducer instructions for the best mounting position.
__________________________________--
Glad to help..................... Good Luck
4/14/2010 5:30:07 PM • Lowrance... • Answered on Apr 14, 2010
Lowrance LCX-15MT GPS Receiver Logo
Popular Tags
48 questions posted
Top Lowrance GPS Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
ADMIN Eric
ADMIN Eric
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
View Most Popular
Lowrance GPS
  • Lowrance GPS
Most Popular Question
gps will not start up
  • GPS
