20 Most Recent Korg PA500 61KEy PROFESSIONAL ARRANGER PA500 Questions & Answers
2answers
The pitch bend of my
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
12/1/2013 7:57:39 AM • Korg PA500 61KEy... • Answered on Dec 01, 2013
My lcd backlight is very
Reading your user manual on page 12, bullet 9 you will find the method of changing the contrast of the display. There is no brightness adjustment possible, however the contrast DRASTICALLY affects the readability of the display.
7/23/2011 2:59:12 PM • Korg PA500 61KEy... • Answered on Jul 23, 2011
I need a fuse for a Korg N364 keyboard.
No one knows the fuse type, but the details should be on the fuse itself. Then you can't get them from an electronics store or Amazon. The Service Manual is in the link. https://www.google.com/search?q=Korg+n364+keyboard+replacement+fuse ..
4/12/2024 4:58:31 AM • Korg Music • Answered on Apr 12, 2024
Korg D3200 asks for start up disc. Will not boot.
If you contact Korg, they can send you a dowloadable link to burn the software to a disc.
11/21/2023 9:36:55 PM • Korg Music • Answered on Nov 21, 2023
Hello. I am in possession of Ix300 Korg music workstation that is not able to boot up properly. Any chance of repairing?
up to you if you ant to spend the money to have it diagnosed and repaired
11/3/2023 2:31:49 AM • Korg Music • Answered on Nov 03, 2023
Loading system failed Korg m50
9/6/2023 8:00:59 AM • Korg Music • Answered on Sep 06, 2023
2answers
Korg X50. When switched on, why does it indicate: 'Waiting for the data from USB'?
Sounds like loss of memory\programming.Go to Korg website for download.
12/30/2022 3:04:37 AM • Korg Music • Answered on Dec 30, 2022
How to reset the korg radias to factory settings
7/23/2022 8:23:24 AM • Korg Music • Answered on Jul 23, 2022
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard. I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings. http://www.midiox.com/ Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced. Hope this helps.
3/8/2022 8:37:05 PM • Korg Music • Answered on Mar 08, 2022
Korg PA500 61KEy PROFESSIONAL ARRANGER PA500 Logo
8 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
lcd backlight very
  • Music
