20 Most Recent
Toshiba SD C2502 Internal DVD Drive Questions & Answers
Help!!!
First shut down any othe apps that are runnig. Even disable norton AV if it is running while watching a move. Second do a disk clean up from the system tools menu, third make sure windows is controlling virtual memory. Finally get a DVD playe like Power DVD. It is much better at playing DVD's than media player that can be a real pig.
My laptop could not read
your drive dvd cd reader is weak that reason your dvd is is not reading plz change your dvd drive
Dvd drive in Toshiba Satellite
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Hi!
can you help me with
One solution would be to go to the manufacturers site and make sure you have the latest firmware update. If your floppy doesn't work, then apparently you are aware of this, and your floppy drive is defective, correct? Moving on then, you can also use a flash drive which are pretty inexpensive right now. It will plug right into your USB port. Another means of getting it into your laptop is to send it to yourself email. Now, if you cannot get passed the need for this to on floppy, then you simply need to get a new floppy drive.
Now, assuming you do indeed have the latest firmware loaded, the problem is the fact of this drive being a bit inferior. It is a dust magnet. Installed in a laptop, it picks up any and every bit of dust that so happens to venture thru.
Solution :. I took the DVD/CD-Rom out, removed the alluminium plate that is held on with 3 little screws and inspected it. I found alittle dust on the DIVERTER(?) mirror/lens. I blew if off, cleaned the primary lens. I reassembled it, put it back in the laptop and now it works fine on ALL CD's. BE VERY CAREFUL WHEN CLEANING THE PRIMARY LENS. BE VERY GENTLE. If this fixes your problem and if you can Please pass this on. It saved me ALOT of money. Almost forgot, the ERROR Message that I would get, before I fixed it was "WINDOWS CANNOT READ FROM DISK.THE DISK MIGHT BE CORRUPTED OR IT COULD BE USING A FORMAT THAT IS NOT COMPATABLE WITH WINDOWS. I hope this fixed your problem.
Same problem (dvd drive deceased, not functioning at all)
You were not at all clear here as to what your specific problem is. If it is the same as the majority reported for model SD-C2502, then you're having a problem with the drive not being able to see data disks, dvd disks, or both. One solution would be to go to the manufacturers site and make sure you have the latest firmware update. Now, assuming you have it, the problem is the fact of this drive being a bit inferior. It is a dust magnet. Installed in a laptop, it picks up any and every bit of dust that so happens to venture thru.
Solution The problem I had was that my DVD/CD-ROM, a SD-C2502,
would only play DVD's, same as yours. Data disks and Audio disks
would not be recognized by Windows. I took the DVD/CD-Rom out, removed the alluminium plate that is held on with 3 little screws and inspected it. I found alittle dust on the DIVERTER(?) mirror/lens. I blew if off, cleaned the primary lens. I reassembled it, put it back in the laptop and now it works fine on ALL CD's. BE VERY CAREFUL WHEN CLEANING THE PRIMARY LENS. BE VERY GENTLE. If this fixes your problem and if you can Please pass this on. It saved me ALOT of money. Almost forgot, the ERROR Message that I would get, before I fixed it was "WINDOWS CANNOT READ FROM DISK.THE DISK MIGHT BE CORRUPTED OR IT COULD BE USING A FORMAT THAT IS NOT COMPATABLE WITH WINDOWS. I hope this fixed your problem.
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
- Unfold the paperclip and make it as straight as possible.
- Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
- Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
- Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
- Remove your disc from the drive.
- Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
