20 Most Recent
Victorinox 8GB Swissflash Ruby Questions & Answers
Never worked, except for some
Start with taking the flashlight to Radioshack if you do not own a multimeter. test the LED resistance. It should be greater than 0 if not the LED is bad.
If that is not the issue then test the connecting points for the batteries. When the buton is pushed to the "on" mode there should be less than 1 ohm resistance in the circuit. If there is more than 1 ohm there is a bad connection in the flashlight that needs corrected.
Good luck and let me know if I can help any more.
Joe
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
- Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
- Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
- Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
- Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
- Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
- Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM •
Camping,...
Answered
on Apr 16, 2024
Do you need special hiking shoes for going on long walks?
Whether or not to buy hiking shoes really depends on what kind of walking you plan to do and how often.Hiking boots are helpful for rougher terrain and for gripping. If you plan to mostly walk on flat ground, you can consider getting good walking shoes instead.
1/25/2024 4:10:25 AM •
Camping,...
Answered
on Jan 25, 2024
What is camp furniture?
Camp furniture is items like tables and chair that are madeout of a durable material, are light and can be folded up and packed.
1/10/2024 2:37:49 PM •
Camping,...
Answered
on Jan 10, 2024
How do you take apart a bushneell 600 lumens flashlight
Taking apart a flashlight, including a Bushnell 600 Lumens flashlight, may not be recommended, as it can void the warranty and potentially damage the device. However, if you have a specific need to disassemble it, here are some general steps to follow:
1. Remove the batteries: Ensure the flashlight is turned off, and remove any batteries to prevent any accidental activation or electrical shock.
2. Look for screws or openings: Most flashlights have screws or openings around the head or tail cap that allow access to the internal components.
3. Unscrew components: Use the appropriate screwdriver or tool to remove any visible screws holding the flashlight together. If there are no screws, try gently twisting and separating the parts.
4. Be cautious with wires: If your flashlight has internal wires and circuitry, be extremely careful not to damage them while disassembling the flashlight.
5. Document your steps: Take photos or notes as you disassemble the flashlight to help you remember
10/24/2023 4:55:23 PM •
Camping,...
Answered
on Oct 24, 2023
COASTHP7 flashlight bulb replacement ?
Try contacting COAST directly. I think they give a Lifetime Warranty on their flashlights. Ask for the repairs department. You never know, they might do it for you under the warranty. There's no harm in asking them.
10/10/2023 9:20:36 PM •
Camping,...
Answered
on Oct 10, 2023
How do chemical hand warmers work?
I actually
just did a lesson on this with my students. When the chemical hand warmer is
removed from the outer packet and exposed to oxygen, it produces an exothermic
chemical reaction, which is a reaction that gives off heat. The result of this
reaction is iron oxide or rust.
10/4/2023 9:30:15 PM •
Camping,...
Answered
on Oct 04, 2023
What are the benefits of sports camps?
The physical benefits kids achieve with athletic activity, such as cutting the risk of obesity, diabetes, heart disease and social and psychological benefits of getting involved in athletics while in school. The ratio of coaches to athletes is always a plus. Most youth sports only have money for one coach, but professional camps like organizers have a skilled coach for playing and training children in
Camps for Youths in your Area. At camp, the athletes will be exposed to several coaches with a variety of coaching styles.
9/23/2023 4:27:13 PM •
Camping,...
Answered
on Sep 23, 2023
