20 Most Recent Hitachi Touro Desk 2 TB USB 20 External 0S03289 Black [Amazon FrustrationFree Packagi Hard Drive Questions & Answers
Its making a strange noise and my computer isnt recognizing it
make sure the lead/s that attach to your hard drive are securely seated if your computer came with a motherboard disc the drivers could be on it click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver hope this helps
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
3/24/2012 6:10:54 PM • Hitachi Touro... • Answered on Mar 24, 2012
3answers
My usb touro external hard
You need to be sure that it is plugged into a USB 2.0 slot. Sometimes USB 2.0 devices will not be detected in USB 1.0 or 1.1, or on low powered USB slots. The back of your computer is the most likely location for a USB 2.0 and is likely indicated.
10/18/2011 9:13:10 AM • Hitachi Touro... • Answered on Oct 18, 2011
0answers
YOU NEED TO FORMAT THE DISK
I think you need to format disc.
3/31/2014 9:22:41 PM • Hitachi Touro... • Answered on Mar 31, 2014
0answers
0answers
Hitachi 50hyt62u H can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store. You can connect a USB hard disk drive or USB memory stick to your TV by using the USB inputs of the TV. This feature allows you to play files stored in a USB drive. 2.5" and 3.5" inch (hdd with external power supply) external hard disk drives are supported. IMPORTANT! You should back up your files before making any connections to the TV set in order to avoid any possible data loss. Manufacturer will not be responsible for any file damage or data loss. It is possible that certain types of USB devices (e.g. MP3 Players) or USB hard disk drives/memory sticks may not be compatible with this TV. Quickly plugging and unplugging USB devices, is a very hazardous operation. Do not repeatedly quickly plug and unplug the drive. This may cause physical damage to the USB player and USB device itself. Do not pull out USB module while playing a file. Media Browser Menu You can play photo, music, and movie files stored on a USB disk by connecting it to your TV and using the Media Browser screen. To do this, perform the following: Connect a USB disk to one of the USB inputs located on the side of the TV. You can connect two USB devices to your TV. If both USB devices include music, picture or video files, USB selection OSD will be displayed on the screen. The first USB device connected to the TV will be named as USB Drive1. Select a device by using up or down arrows and press OK
11/30/2019 1:10:18 PM • Hitachi... • Answered on Nov 30, 2019
How to connect my Mac book pro to a Hitachi projector
You will have to use the HDMI port on the mac. provided you have a HDMI input in the projector
11/26/2019 12:41:17 AM • Hitachi... • Answered on Nov 26, 2019
HiTaChI pRinTeR inStaLlAtIoN cuStOmEr sErViCe nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
BENJAMIN, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/7/2019 5:39:59 AM • Hitachi... • Answered on Nov 07, 2019
My Hitachi XL500 external hard drive is not showing anywhere on my computer. I also do not believe any power is getting through to my hard drive. Please help
buried in endless spam are you. does it fail on 2nd PC???????????????????????????? but yes, I am the MVP of external HDD< I build my own. Have over 5 here for Backups . lots of causes, for sure bad drive, or missing drivers.. bad HW hardware or BAD software SW. Missing 12vdc 2amp power pack>, lost or using wrong one. when pack above does the HDD spin? usb connected to PC. NO PC stated, NO OS stated, windows/chrome/Linux/android? its at lease 10 years old , see posts back that far. not good old HDD,this old. sold during W7 era. 2009. The drive has 3.5" HDD that needs lots of power (Amps) to start up that big motor inside, and is first thing to learn . 2amps it needs, ok? so if pack is missing it will never startup on any USB port, not rated for 20x standard USB load factors. some laptops only do 0.1amps (100mA) and are useless to startup any hdd motor of any kind. see why here. and see a better extremal solution cheap.! $10 http://www.pcdied.com/external-hdd.html
7/3/2019 1:28:14 PM • Hitachi... • Answered on Jul 03, 2019
I have an Hitachi VM E510A that has a 6 volt dc input but I can't find an end to fit it. What size is the cable end. I would order it if I knew the size
Tried googling for the answer but couldn't find it. Try calling an it support company, I'm sure they'll help you out for free. Perhaps you can try https://www.computersinthecity.co.uk/, they have been helpful to me in the past.
12/7/2018 11:28:10 AM • Hitachi... • Answered on Dec 07, 2018
Hitachi Touro Desk 2 TB USB 20 External 0S03289 Black [Amazon FrustrationFree Packagi Hard Drive Logo
Popular Tags
8 questions posted
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Touro Hitachi
  • Touro Hitachi
Most Popular Question
its making strange noise computer isnt
  • Computers & Internet
