20 Most Recent
Bunn My Cafe MCP Questions & Answers
Why does it leak around the top of the K-Cup holder?
Too much pressure makes the poor seal around the spray head leak. It happened to me, too. Call Bunn. They sent me a new one free of charge. Plus, you have to use purified water and clean it regularly to prevent buildup like calcium from causing similar issues (I use a gravity water purifier, but it doesn't remove natural minerals). I've had mine a year and that was the only problem. Much better than the multitude of Keurigs I had before.
The awful difficulty opening the drawer will subside with use.
And, they stand behind the machine in full for the 2 year warranty, meaning they'll replace the whole thing free if something happens
Won't shut off after making a cup
It sounds like the thermostat or Element is failing and causing your unit to overheat and boil. Probably time to call Bunn and see if your unit is under warrenty.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
