20 Most Recent
Dell Latitude E5420 Laptop Computer Questions & Answers
How to install webcam driver on my dell e5420
Did your webcam come with a disk? If so run the disk on your computer this should have the driver. If not, the maker of the webcam will more then likely have a website where you can get the driver.. Simple download the driver and install it.
Windows may even find a driver its self.
Screen upside down
U can change the direction back in video settings....which os do u use? usually it will be present where u change the video resilution and frequency...
How to run fifa 13 on my dellLatitude E5420
Hi Navin,I understand that you are unable to install the FIFA 13 in your Dell Latitude E5420.Please provide me the following information1. Operating System2. Bit Version3. Do you have any other computer?4. Error message that you get with screenshot if possible.5. Are you able to run the same DVD FIFA 13 in other computer?This will help me to isolate the issue and try to fix the issue.
Dell e5420 wont start up at all
Make sure no accessories are plugged into your laptop. First remove the battery and try a bootup. If does not bootup, remove the hard drive if you can and try again. If still no full boot, you can try the DVD drive and then the memory. Replace what you have found to be the problem. If none solves the bootup problem, it is either the power supply itself or a mainboard problem, which would required service from an authorized service center from Dell. Verify the center with Dell. The parts I have indicated to try are normally easily removed from the bottom of the laptop, by removing a few small screws.
Boot sequence password
restart the computer and HOLD the keys CTRL or FN + f2 or ESC depend of your mark, model, and enter the BIOS setup select boot sequence and enable, and ready.God bless you
I HAVE DELL LATITUDE E 5420. THE MIC IS NOT RESPONDING, IS THERE BUILT IN MIC SETUP IN LATITUDE E5420 LAPTOPS. PLEASE HELP ME OUT
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
window 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select
properties at the bottom select use this device enable
hope this helps
Dell e5420 close lid power problem
What is the problem? Open Control Panel, Power settings, Advanced power settings, set to High Preformance, Set Sleep and Hibernate to Never , Set Lid close to Shut Down, adjust setting to your preference, Always shut down your Laptop, unplug when not in use. Remove battery if you use on AC most of the time, your laptop will last longer and a boot everyday resets the computer.
Lost admin password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
