20 Most Recent
Palm Pixi Plus Cell Phone Questions & Answers
I have purchased a Verizon
yes its possible to activate call plus data of reliance cdma on verizon palm pixi plus .
Required a special procedure .
Contact me by email
cicinfovision[@]yahoo[.]com
I am using Palm Pixi
if any 1 who wants to sell his palm pixi plus den contact me on 09224874010....thank u.
Cant unlock puk code
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Can't download any video
hi, the only file that you can save on your phone are the only files that your mobile phone supports...all you need do is to make sure you check the format the videos are saved before you try to download them.
cheers.
My phone fell in the
One of the best things to do is put it in a bowl of rice right away. The rice will absorb the moisture from the phone.
Take the back cover off, take the battery out (if applicable), and then put the phone in the rice.
Hopefully it is not too late and this will help.
If this has been useful please rate it, thank you!
My first problem:
I have a Verizon Samsung Alias
No, you cannot unlock the Palm Pixi Plus and put it on a plan that is not compatible with a smartphone. If you want to continue to use Verizon service, you will have to purchase a phone that is compatible with your current plan, or change to a different plan that will work with your Pixi Plus.
Whenever i call someone or someone calls me my
Check the proximity sensors on the front of the phone, if they are dirty or covered by a screen protector or case, they may be malfunctioning and preventing the screen from coming back on. They look like small circular sensors, probably above the phone screen.
