20 Most Recent
Toshiba e355 Pocket PC Questions & Answers
The e355 is not reading
Welcome to Fixya.
If you MacPro has a built in card slot and it can read SDcard then you don have any problem there. All you need to do is to insert the SDcard to the macpro then browse your files. If your computer doesnt have any card slot then you need to purchase usb card reader for SD card.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Can I access internet on a Toshiba e355?
If your cellphone supplier won't demo it, then it's best to say it's not going to work.
Instead, the outlook is that WiFi hotspots will be the way to go since you won't get soaked on cell charges.
Toshiba e355. Wireless?
"Certain Pocket PC Models have SD or SDIO slots but are not compatible with the SDIO WLAN Card. These include: Toshiba e350 and e750 – these have SDIO slots but do not have SDIO Now! software from BSQUARE. The e355 is the same as the e350.
GPS-card possible in SD-slot?
As far as I know there is possibility to use Compact flash but no SD. I also know that you can find a lot of solutions that use USB or Bluetooth connection for GPS.
DEACTIVATE TOUCH SCREEN ON TOSHIBA E55T-A5320
usually on toshiba you have to download the touch pad file from the manufacturers web site unless there is a disable in the bios
this varies by model...be sure to get the right "utility file" for your particular model
4/16/2014 10:07:44 PM •
Toshiba E...
Answered
on Apr 16, 2014
D900 wincedll.cab where to download?
http://driverwhiz.com/drivrutiner-se?brand=Toshiba&logo=Toshiba&subid=1001-se-se-10000008911&gclid=CInI5-y5srYCFdB3cAod_jQAGg TRY IT'S NOT FREE
4/5/2013 2:15:03 AM •
Toshiba E...
Answered
on Apr 05, 2013
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
