20 Most Recent
LaCie 2TB Network Space 2 A) Questions & Answers
No ethernet disk available
Hello, This is not my turf. Would guess that green means go and that channel is okay and orange means problem for the other channel. Would suspect that you had something running on the orange channel while the Download was going on, as most Downloads want you to exit running Programs.You could try to Download the info again and I hope you use a Restore point, for that matter, a Restore point should have been created before the first Download. Sometimes Firewalls and Antivirus software will block parts of a Download to make the Download usueless. Some Antivirus Programs can be put to sleep while important Downloads are conducted. If you trust the site, turn off your Firewall and Antivirus.
12/8/2011 8:40:48 PM •
LaCie 2TB...
Answered
on Dec 08, 2011
Unable to access dashboard
had same problem. I was able to resolve my dilema by finding the ip address of the unit (from router admin interface ). then I entered the address in my browser address bar. It now appears in my browser address bar as(lacie icon) http://(ip address)/dashboard/. admin page then loads (have passwords handy as I don't remember for sure at what point the unit requests them). My unit is presently unusable with a different issue or I could be more step step specific. hope this helps. fyi turn off auto update for unit software as I am pretty sure that was source of my current problem.
12/4/2011 9:23:11 AM •
LaCie 2TB...
Answered
on Dec 04, 2011
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
