20 Most Recent
U.S. Robotics (USR5633A) Modem Questions & Answers
Dear Sir or Madam I
Go to Devive manager update device driver of the Modem and then creat new coonection , that's is .
(run)-->devmgmt.msc-->select modem-->r.click-->Update driver-->choose .inf file from ur modem driver folder.
Password
normally it's 1234 on default. if you got it from your provider, you should contact them.
Range of wireless very limited
go to http://192.168.1.1
use username - admin
pw - admin
go to setup->wireless->advanced...
set the power level -> full
it will work
Hardware problem of siemens C2110 ADSL modems
hello.. i am using the same modem c2110 since 10 months. It was working smoothly, but now since a month above said probelm facing. It is getting connected, but after some minutes(sometimes 10,20,30,,,) the link light blinking. sometimes it becomes stable itself. I tride a solution, removed the phone cable from modem and connected it to a phone, just press speaker phone to hear dial tone, the re-fix it to modem, it works...! but just for sometime only...and repeats the problem. .what is the solution?
Windows server 2003 installed two usb us robotics
double check the IRQ assignments and the com ports.
It is possible to run these modems as "shotgun" but taks a little patience and work.
Also double check what you have for IRQ settings in the bios etc as this too can hold off two modems from working properly.
Download speeds slow
Thanks for sending this solution it has also help to fix mine too even though I'm using windows vista but the solution was the same
